Question about Brother MFC 210C All-In-One InkJet Printer
Not using generic ink for black
My question is I have changed the Black 2 times and it still does not print in black and I am about to throw this printer thru the window. LOL.. please help
  • Melomom Jan 06, 2008
    Printer says to open cover, ink empty (on all three colors) except the black. We are using Brother products straight from the original shipping container. After unplugging the unit, removing all the carts, waiting 30 minutes, replugging, inserting the new carts, we continue to get the same read out and the machine is not functioning. Yes, I feel like throwing it in the garbage, but I've spent (wasted) so much on carts that I'm trying to be patient. HELP!!!
  • 832 Answers
@robgat:
Did you use generic carts? Those do make a lot of trouble. Use another cart.
Make sure the cart is placed well and secured (white plastic nose).
press menu then start bk copy then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning procedures. leave maintenance mode by pressing 9 then 9. do run a test print.
If you still cant see any bk the ph is clogged and cant be fixed anymore due to wrong ink consistence of the generic ones.
@Meloman:
If you use original carts make sure you have placed the carts well and they are secured! Give answer to display info!
If you still receive the error in question, have a look at the right hand side of the cart holder. Here you will see the led control board which might be out of position and needs replacing. Open printer and reinsert the small board.
Posted on Jan 07, 2008
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
My printer will not print black even tried 2 brand new cartrages. i also tried the cleaning process on the printer and it did not help. all other colors print perfect.
the black tube or nozzles are clogged up. The printhead probably needs to be replaced.
possible reasons for this
generic ink
not using the printer for a long time
printing past the warning indicator of low ink and having air get sucked in the tubes.
Probably cheaper to buy a new unit.
Aug 27, 2010 | Brother MFC295CNAll-In-One InkJet Printer
Black ink in brother 240c printer does not print new cartridge
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have replaced my black ink cartridge, and the computer still tells me i'm out of black ink.
Are you using Generic cartridges. See Below:
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epson2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Oct 11, 2009 | Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
Are you using Generic Cartridges? Pls See Below
Good Luck :0(
Oct 08, 2009 | Epson Stylus C84 InkJet Printer
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hp psc1210 will not print black but will print gray
Gray print does not use black ink. It only uses the color cartridge. I assume you already changed the black cartridge. Make sure it is the right one for your printer and it is not a generic refill. The generic might be OK but I wouldn"t trust it complety. Make sure your cartridge is properly seated in the holder.
Aug 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Only print on black and yellow
did you use generic ink? those ink will clog the ph espacially the mag + yellow channels.
do use original brother ink carts because these contains special cleaning fluids!
Mar 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
PRINTER CANON PIXMA IP1500
your printer maybe long period of time does not use , the head already dry , replace w/ " original canon ink" not a generic.
Dec 28, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Blk won't print
Do you use generic carts? It could be that the generic ink has clogged the filter in side the printhead.
Do run the machine with original ink carts and try the following:
Press menu then start mono then four times arrow-up. machine will be in maintanance mode. press 7 then 6 then 3. Press start mono. Machine will do a power purge. Press 0 then 9 machine prints test sheet. You might do the power purge a 2nd time. Leave the maintanance mode by pressing 9 then 9.
If you do not have more black blocks the printhead is clogged and cant be fixed anymore!
Nov 02, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
