RCA Scenium HDLP 50
Can turn the tv on, no picture/sound. "Unusable Signal, Signal Strength 50" appears on the screen. About 5 months ago I had the ballast replaced along with the color wheel and the lamp. The wheel and lamp were not bad. I bought and replaced the lamp. I then had to call a repairman. He did the rest. Thanks for your suggestions.
Comment by JGFan, posted on Jan 06, 2008 Thanks. I had a feeling that was what was wrong. Do you know where I can get a service/repair manual?? Do you know what the tuner looks like or where it is inside??
Comment by JGFan, posted on Jan 06, 2008 The signal strength I'm going to say is good because all of my other tv's are working just fine.
Comment by JGFan, posted on Jan 06, 2008 I accedentially hit the "Accept" button under one of the problem solution suggestions. I could still use some help. Thanks
3 Suggested Answers
SOURCE: RCA Scenium HDLP 50
Sounds as though your tuner module is not working or you have a lack of signal to the tuner. You need to be sure that the set hasn't been switched to a different mode ( ie: from tuner to video..etc ). If all is correct in that matter, are you using a satellite dish. If you are infact using a satellite dish, then the signal strength from the satellite is not suffecient. ( you may need to realign the dish ). If you are on a cable signal ( cable TV ) you may have a bad input cable and need to call the cable company to check their input line. If all is well with the signals coming in, then infact, you may a bad tuner module in the TV. Good Luck
Ed NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • 2427 Answers
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
No picture/sound
CONTACT RCA FOR REPLACEMENT PARTS OR INFORMATION
here are some contact information for rca
http://www.rca.com/content/viewdetail/1,2811,EI45168,00.html
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
1-866-SCENIUM.
Jan 06, 2008 | Televison & Video
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium HDLP 50
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
