Carrier LFP Humidifier
Problem for Carrier LFP Humidifier
Fan does not run
By razo on Nov 09, 2009
Fan does not run
Solution #1
posted on Nov 10, 2009
Not Rated)
co7196
Rank: Wiz  Air Conditioners  Expert
Rating: 84%, 1099 votes
Hmmmmmm, does it seem to try? If so, help it with a spin and maybe a little spray of wd49 on the motor shaft.
Was this helpful?
Yes
No
Popular Solutions for Carrier LFP Humidifier
Questions and Unsolved Problems for Carrier LFP Humidifier
Do you recommend Carrier LFP Humidifier?
Answer
Answer
Hi; When I turn on the humodofier control (even to test) it never "clicks" to show that th... (More)
Answer
how to replace plates in autoflo 100
Answer
water valve stays on all time 2001 model
Answer
When my furnace and humidifier first cuts on, the pipes rattle violently. This subsides after about... (More)
Answer
I have a carrier humccsfp1016a and it is leaking all over the fl. I changed the filter ans it still... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Carrier LFP Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2540
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
