Question about Ricoh Aficio CL2000 Laser Printer
SC 441 I have a error message on my printer that says SC 441 Power Off On. I'm not sure what I can do to try to fix this myself. Any suggestions? You can e-mail me at randyweaks@comcast.net
  • 2 more comments
  • Anonymous Nov 07, 2008
    i have the same problem
  • Anonymous Jan 09, 2009
    Please help. Same problem.
  • Anonymous Feb 11, 2009
    same problem, it doesnt work with a new PCU. Also, i switched between engines with another printer... NRG C7521 is my model
  • Anonymous Feb 23, 2009
    I have an error:SC441 power on/off. What can I do?
  • 417 Answers
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Posted on Jan 13, 2008
We had the same problem and we had two printers at our place and we swapped the photo conductors, it worked.
We first tried swapping the black photo conductor, it did not work.
We swapped the color photo conductor and it worked.
Solution for error SC 441: Change your color photo conductor.
Thank you
Sri
Posted on Mar 10, 2009
  • John Kish Nov 03, 2010
    I had trouble with this error SC411 after using one after market yellow toner. I changed the color PCU.
    New Friend:
What do I do when I receive a message cs441
Posted on Jul 23, 2013
Thanks!
Posted on Aug 12, 2008
Error 441 mp 4000
SC 441 Trans/development motor error - check for binding/overload on motor -Carl
Feb 25, 2015 | Ricoh Office Equipment & Supplies
Error sc 441 mp4000
Feb 25, 2015 | Office Equipment & Supplies
Error sc 441
SC 440 main motor malfunction.Check the gears and the drum motor mechanical parts on the drive transmissions.For more details please the copier model.
Mar 05, 2013 | Ricoh Office Equipment & Supplies
Repair error 441 in cl3500dn printer
SC 441 - development motor lock.Possible causes:
too much load on the drive mechanism
development motor defective
poor drum motor connector connection
interface board defective
Feb 03, 2013 | Ricoh Aficio CL3500N Laser Printer
I keep getting error SC 705, how can I fix it and can I fix it myself?
Its a problem with the Document feeder, try turning the copier off unplug the doc feeder and turn power on. -Carl
Nov 18, 2010 | Ricoh Aficio 450 Copier
My printer flashes alert CS 441 off on. Can you tell me what's wrong?
The SC 441 is a color pcu motor lock. One of the waste toner augers is clogged with waste toner not letting the drum turn. The only real fix is to replace the color pcu unit. If you could get the auger and drum out it might be possible to free it up, but you will probably damage the drum in the process.
Apr 15, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Mar 03, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Error 441*
Error #441 is caused by poor line quality accross the telephone line or faxing to a non-compatible fax. Try faxing to someone else as a test, if it still happens, try moving the fax to a different phone jack. You can also try faxing at a differn't time. Also try replacing the phone cord attached to the fax.
In all cases it's either phone line, phone cord or non-compatible machines (old fax on receiving side).
Aug 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Ricoh Aficio CL2000 Laser Printer Logo
7,066 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
