Question about Daewoo Microwave Ovens
DAEWOO Microwave Oven KOG-311M, Dead
I always let the power plug connected to the utility outlet. One day the power is suddenly disconnected, when it comes back, I found the display is dark, not as usual. I checked the component, I found out that the control board transformer was burnt out. The transformer's label is "DMR-604FS
5EPV041354". I need its schematic to know the input and output voltage at its terminal, in order to substitute it by any standard available.
Thank you
Ashraf Awad
a_awad@hotmail.com
4 Suggested Answers
  • 8909 Answers
SOURCE: operating manual for daewoo microwave
Contact Daewoo's web site for manuals free of charge.
Posted on Dec 20, 2010
  • 49 Answers
SOURCE: Daewoo Microwave KOG 867 T9-DEAD??
There could be a main fuse inside the unit. Mine has one that is ceramic, sort of like the old glass car fuses but ceramic instead of glass. Digi-Key has all kinds of fuses, www.digikey.com.
Posted on Aug 04, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Daewoo microwave
Contact Daewoo Technical Assistance at 1-877-393-2725.
Posted on Aug 21, 2010
1. Microwave noise 2. keyboard and beeping
Make sure oven is plugged into a grounded outlet, and that the outlet is actually grounded.
Although extremely rare, I have seen ovens where insects were walking on the back side of a control panel, and causing problems. Could also just be some sort of electronic failure.
Mar 14, 2016 | In Microwave Ovens
MY DAEWOO MICROWAVE KOR 1B4 H JUST STOPPED WORKING.
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Dec 01, 2015 | Daewoo KOR-1B4H Microwave Oven
I put my Microwave on for 30 min and it suddenly stopped working, suggestions?
If there is no power at all to the display or the panel then it is failure of the board. But if there is power without heating, if the turntable/fan/light works, then it can be related to failure of relay, Magnetron, Waveguide or capacitor.
Jan 31, 2013 | GE JVM1650 1000 Watts Microwave Oven
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
Display & lights go out after use when door is opened, can uplug unit, then plug back in and display & lights work again until next use
If it's doing that u may have a short in the cord somewhere I would try while plugged in next time u use it don't unplug it but next time it goes out move cord a little bit n see if it comes back on if so that's the problem r u getting bad connection somewhere try another outlet too
Feb 10, 2012 | Samsung SMH7185STG Stainless Steel...
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
My microwave oven model kog-134k is not heating food, otherwise its functioning well.
The problem is caused more than likely by a defective magnetron, "heats food" because it is the heart of the microwave oven it is the most expensive to replace, it is cheaper in the long run to buy a new unit rather than have it repaired.
Jun 19, 2011 | Daewoo Microwave Ovens
My deawoo kog 868 gsl micowave will no longer microwave?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 08, 2010 | Daewoo KOG-867T Microwave Oven
Microwave Ovens Logo
234 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
