Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not stay powered up
When I push the power button to cut the monitor on the button lights up green and then powers off. I continue to push the power button but the tv will not come on or show a picture. The tv is about 2 1/2 years old.
    Genius:
  • 1,030 Answers
This units processor has detected a fault and has shut it down for safety. This means it can be one of about 30 different cuircits that are at fault. this is where troubleshooting starts. technicians have special diagnostic equipment for rca that will read errors in the processor. are u a technician. there are basic voltage checks that can be performed. Warning televisions generate potenitally leathal voltages. do not remove back unless qualified.
Posted on Jan 07, 2008
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Won't turn on
This is a problem with either the power supply or or logic circuit. It could also be caused by a failure in the back light circuits. One of these problems has caused the power supply to go into protection mode and will not turn on due to bad voltages sensed in the feedback circuits. Return to dealer for service. Hope this helps you .
Dec 26, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Vusys hd19a monitor is always on standby
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Dec 11, 2008 | Microsoft Likom HD19A 19" LCD Monitor
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Power button doesn't work...
Your problem is not the switch. Probably you have faulty capacitors, deteriorated solder joints or worn out bulbs.
To open the case, remove the base (push button and lift off).
remove any screws under the base plate.
Pry the front and back cover apart, they snap together.
Good luck,
Monitor Mike
Oct 12, 2006 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
