Question about Kenmore 27032
Water leaking out of pump
I have a kenmore washing machine 110.26702693, it is leaking water out of the pump how do I fix this, ( taking off the pump) I can't figure this out.
Thank you,
Vicki
  • vkidsplay6 Feb 06, 2008
    I had a problem getting the pump off. It was rusted so bad that it was stuck. I then had to take sand paper and sand the shaft down to get the new one on it.
    Thanks for the help,
    Vicki
  • 51 Answers
Unplug the washer. The consul is hinged from the top. Remove the two screws at the base of the consul ( at the front or the back) and pull the consul toward you then flip the consul back. You will find two gold colored spring clips under the consul. Use a screwdriver in the front slots, pop the clips out. Unplug the connector to the lid switch, tilt the cabinet forward and set it to the side.
Remove the two hoses to the pump and the two spring clips that hold the pump on. Your half way there. replace the pump and reassemble the machine. make sure you line up the cabinet. Cost should be about $50.
Posted on Jan 07, 2008
I have Kenmore elite washing machine model: 11045088401. It started leaking water from the drain pump. How would I fix it?
If u have seen the water leaking from the pump the only fix is to replace the pump..
Dec 13, 2012 | Washing Machines
I have kenmore washer. when I open door, I found water in there. So i drain water and washed. After two day, I found same level water in cabinet. I think water leak in side or didn't operate water presure...
If the machine is not pumping the water out during the spin cycle, then it could be a couple of things. First, it could be that the cycle timer is faulty and needs to be replaced, or it could be that the water pump is bad and that needs to be replaced. Either way, the repair is cheaper than a new machine.
Mar 07, 2011 | Kenmore Front Load Washer
My Kenmore 80 series topload machine is leaking water
This machine has a direct drive pump, in all likelyhood the pump is leaking...unplug machine...pull it out...tip machine on its back so you can access the bottom, if it is the pump there should be water around where the pump connects to the motor, if it is the pump it is a simple process of releasing 2 clips and taking the inlet and outlet pipes off the pump..install new pump the way you took old one off. you can obtain the part from www.repairclinic.com If you would like to give me more details on your dryer i may be able to work out what is wrong with it.
Jun 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Apr 26, 2009 | Kenmore Washing Machines
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 110.2949 water leak from center front of unit
Check your pump. The pump is located on the end of the motor. You can tip the machine back and pull the pump off to check it. After you take the pump off. Check to see if there is a water stain where the shaft of the motor goes through the pump. If so you pump is leaking.
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine leakes some where frome the bottom of washer
It sounds like you pump is leaking. This happens most of the time( if its a kenmore or whilpool)lean your washer back and then you will see the pump on the end of the motor. it is held on by 2 clips and then you can take it off (after pulling iff the 2 water hoses) Look at where the motor shaft goes onto the pump if its leaking there will be a water streak. Replace the pump... leak is fixed
Oct 28, 2008 | Kenmore 23822 Top Load Washer
Leaking
check your water valve at back and your water connection.if there o k it probably is your pump.
Nov 12, 2007 | Kenmore 22422 Top Load Washer
Kenmore 27032 Logo
88 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
