Question about Bosch WFMC 3200 Front Load Washer
Liquid between the plastic window of the door
Hi, accidently I droped softener on the top of my washer and some liquid got between the plastic window of the door. How can I take off the front cover of that window without breaking it.
Thanks
    Novelist:
  • 130 Answers
Well now the fun begins. The plastic window won't come off without breaking it. However you can seperate the door. Open the door to the stop and with a t20 torx bit remove the 4 screws that holds the door to the hinge. Then as you close the door it will come off. Lay the door on a towel with the face down. With a putty knife along the inside outer edge stating at the bottom of the door, you can divide the door in 1/2. Now you can get to the panel you want to clean. Use care when doing this as it is possible to break the door. The top (handle) of the door will be the last piece you pull out. You reassemble in reverse order.
Posted on Jan 06, 2008
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
Residue left on clothes from no agitator top load GE washer
Do you use liquid laundry detergent & liquid fabric softener? If you do then this could be the source of the residue that is getting on your clothes. Over a period of time the gummy residue from liquids will accumulate between the tubs. You can clean out the washer with a product called Washer Magic or the unit will need to be disassembled & cleaned thoroughly by hand. Do not let raw liquid detergent or fabric softener come into contact with your clothes.
Also, here is a link to the agitator cap if you should need it.
Aug 12, 2012 | GE Washing Machines
Hi, I have kenmore washer and after washing my clothes getting some white stains on them. How to solve this problem?
If you are using a liquid fabric softener , then start using dryer sheets instead OR using less softener . Also be sure you are using the correct temp setting for softener " disolvement " . Re-washing the clothes should take out the spots . If you have dryed the clothes , may take several washes to remove the spots .
Aug 05, 2010 | Kenmore 24032\24036 Top Load Washer
Can i use liquid fabric softener in this machine?
If your Admiral washer has no liquid fabric softener dispenser on top of the agitator, the instructions say to dilute the recommended amount of softener with 1/2 to 1 cup of warm water and add it to the rinse cycle. The manual also states that you should be careful not to pour it directly on the clothes or on the tub, only into the water.
Jul 07, 2010 | Admiral 32 cu. ft. Washer
Where do I put in liquid fabric softener?
behind the soap dispenser is another spot for softener
May 24, 2010 | Maytag EPIC MFW9700S Front Load Washer
Soap in wrong dispenser
Just do one or washes with an old towel in the drum. Keep doing these washes until the m/c no longer froths.
Oct 04, 2009 | Kenmore 42822 Front Load Washer
Where to put the detergent and liquod softener in newHaier washer
Detergent goes in the drum with the clothing, fabric softener in the middle of the agitator, the drawer is for delayed start if using soap powder
Apr 04, 2017 | Haier XQJ50-31 Top Load Washer
Softener
that cap has a rubber o-ring at the edge. it covers the nut so that no liquid would be spilling on the metal nut . just slowly press the cap downwards the inside of the agitator and press it firmly then put back the softener container on top.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Kenmore 24032\24036 Top Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Fabric softener is left in bottom of drum after wash cycle completes
We had the same problem. You have to remove the part that the softener goes in and clean it. You will be amazed at how much build up is in there. That solved the problem for us.
Jun 18, 2008 | Maytag SAV5710 Top Load Washer
Bosch WFMC 3200 Front Load Washer Logo
190 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
