Question about Speakers & Subwoofers
Wiring a goodmans ghc 50 surround sound system
How to wire the speakers to goodmans ghc 50 sound system
  • 1199 Answers
SOURCE: speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Posted on Dec 28, 2008
0 characters
1 Points
How can i hook up surround sound without an actual sound system?
You can draw up a chart to show where the speakers would go.
Use some imagination and go into detail .
When watching a movie on the virtual surround system , pretend to adjust the volume of each of the 5.1 ( or is your system a premium 7.1?) channels to suite your audio needs.
Use small cardboard boxes and draw speakers on them... some of Moms thread , or some old kite string will do for wires too!
Be carefull not to cross the wires (string) or you may cause a short in the system and blow out your nice new system!
Sep 28, 2011 | Speakers & Subwoofers
I have a Jensen JHT805 surround sound I recently aquired from a local flea market, it is in great condition. But The speakers don't have the required wires needed to make them all produce sound. The...
The speakers require a special Speaker wires that can be found at any big markets...
Just visit any local market ,preferably Electronic stores and ask for it..
it is a piece of can do it....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Jul 01, 2011 | Jensen JHT805 System
No matter what I do, I'm not getting any sound from my surround sound speakers, switched the wires around on the modual (swapped front and rear) and got sound out rears, so speakers are okay....I'm no...
Verify that all speakers are wired with the proper polarity and that they are making good contact, then verify that the speakers are receiving a signal with a multimeter, and check the impedance of the speaker as well to make sure they are not blown.
Mar 15, 2011 | Bose Acoustimass 6 III System
What wire do i use to use all speakers at once???
that is surround sound system,,they hook up seperatly,,not together,,that would blow something,,,one wire to each channel and each speaker,,
Nov 04, 2010 | Coby CSP-94 Speaker
My surround sound shut off and sound went to tv as it's output source
try unplugging it and pluggin it back in. and make sure no wires are touching that would make it shut down.
Oct 06, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I spliced some extra wire for 3 speakers on a surround sound system. they aren't working but the other two that aint spliced work. what could be the problem?
Bad splice job? Remove your spliced wires and reconnect as original to make sure original wiring is still ok, then start over.
Jan 01, 2010 | Speakers & Subwoofers
5.1 surround sound system
perhaps you wired the subwoofer backwards, you got the positive and the negative mixed up on one of the speakers
Dec 26, 2009 | Speakers & Subwoofers
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Front audio channel burnout
Resistors can fail from being turned up to hire, wires getting bumped together or against metal, speakers being wrong ohms, or just plainly overheating.
May 22, 2009 | Harman Kardon HKTS 5 System
Need help with my suround sound system
try wiggling the cords.i think it's open from the inside of the cord.sometimes attaching and pulling cords is the cause of no sound at all.check your cords for can use a battery and a small lamp and wires.make a circuit of a lamp.then, get one wire from the small flashbulb and use it as a probe.the wire from the battery is the other.hook it up to your cords touching the one end ,like completing the circuit.if the bulb lights up it means it's ok and if not, your cord is open.
May 15, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Speakers & Subwoofers Logo
988 people viewed this question
Top Speakers & Subwoofers Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a Speaker and Subwoofer Expert? Answer questions, earn points and help others
