Question about Sebo X4 Bagged Upright Vacuum
Brand new sebo x4 won't turn on. It has never been used.
I purchased a sebo x4, brought it home, plugged it in and it won't turn on. Is there something that has to be done first?
  • doozy Jan 08, 2008
    Thanks for the info. I did take it back and discovered that the problem was a wire in the circuit housing that hadn't been properly connected. The tech had it running in minutesI love it! Works like a charm. I traded the Dyson in that I foolishly bought about a year ago! It worked great for a very, very short time and then it was garbage!
  • 1,673 Answers
No, and being under Warrenty, take it back to where you bought it and have it looked at. You will void the Warrenty if you do anything to it. One thing to that you can check is make sure that the handle is all the way inserted and locked. The vac. is shipped with the handle not installed and will not turn on if not all the way inserted.
Posted on Jan 06, 2008
How to remove retention clip on sebo x4 to repair electric cable
Check out Espares video on how to repair and replace cable on the SEBO X1. It is the same machine as the X4, only difference is a different motor and cosmetic differences. I rely on this video and a few of the others that this company have done on You Tube for SEBO repairs.
Don't forget to rate, thanks.
May 20, 2015 | Sebo X4 Bagged Upright Vacuum
Sebo vac grinding noise and burnt smell
Take it to your local vac shop for assessment. Sounds like a bad motor. If they are not a Sebo dealer, make sure they know that a X1 motor is not the same as an X4 motor. It should cost around $200 for the total repair . A new X4 is $799 so the repair is usually a good idea.
Jun 16, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Hi, I've just had my Sebo X4 back from being repaired (motor was growling so Sebo replaced it FOC under warranty) however, the replacement motor is 1000 watts. I queried this with Sebo, as they c
Watt= volts x amps So what are you losing? Not much really. Should they replace it with the same motor? Possibly, but you got a free motor out of them. To be honest I think you're splitting hairs on this one. The difference in how much cleaning that sebo will do with one motor vs the other is beyond minimal. The aggressive brushes on that vacuum do 95% of the carpet cleaning and both motors will have no problem turning it at sufficient speed. As far as suction goes I'd be amazed if it was even a noticeable difference. That's an amazing vacuum you bought, I wouldn't worry about it and go on with life.
Good Luck
The Vac Dr.
Nov 12, 2012 | Sebo X4 Bagged Upright Vacuum
Brush won't turn
There is a good chance the belt is broken. The reason belts break is because the brush seizes up due to hair wrapping around tight at the ends of brush. Inspect closely with a flash light to check for this.
Aug 18, 2011 | Sebo X4 Bagged Upright Vacuum
I need a new set of instructions for my sebo x4 extra upright cleaner
you will have to call sebo or the dealer you brought it from to get manual
Aug 27, 2010 | Sebo X4 Extra Bagged Upright Vacuum
My sebo x4 extra does not start. There is power but no warning lights are flashing. When I turn the vacuum on there is a continual clicking/buzzing sound.
Eeither motor or servo motor with gear box is seized. Testing is done energizing the motor. Test and repair must be done by a technician. Call the number listed on the owners manual to contact a qualified repairer.
See: Parts List and schematics SEBO X4
Jul 31, 2010 | Sebo X4 Bagged Upright Vacuum
I have many SEBO automatic X4 vacuums with broken foot pedals. I would like to buy 5 foot pedals that I believe the part number is 5059DG can you tell me where to get it
I guess that depends where you live... plenty of spares sources online (google sebo vacuum spares)... otherwise google sebo dealerships in your country/locality.
Feb 19, 2010 | Sebo X4 Bagged Upright Vacuum
Sebo X4 is squealing when pulled back. Takes a while after it's been running for this to happen. We changed the roller brush (needed it anyway) but didn't take care of the noise. Could the wheels be...
Yep - we think Sebos are pretty good too. I work at a Sebo sales and repair dealership! The wheels are a good bet - I can't think of anything else that might cause the noise. If in doubt, I suppose you could simply wheel one around for a while when switched off...
Feb 15, 2010 | Sebo X4 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
198 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
