Toshiba 65HX83 65 in. Rear Projection HDTV-Ready Television
Problem for Toshiba 65HX83 65 in. Rear Projection HDTV-Ready...
Hi, tv set goes into standby,when you reset the
By godredger on Nov 09, 2009
Hi, tv set goes into standby,when you reset the picture is bright green for about 10 seconds and goes back into standby.
Best Solution
posted on Nov 10, 2009
Very Helpful)
jeffharris42
Rank: Wiz  Toshiba Televisions & Videos  Expert
Rating: 80%, 20 votes
tv is drawing too much current and protection circuit kicks on and shuts tv down. try turning all screen controls all the way down. if that doesnt fix it, sounds like bad green picture tube. suggest local service center
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you Jeff, I was told that the green picture tube was bad by someone else. I will take the set to a local tech. " - godredger
Popular Solutions for Toshiba 65HX83 65 in. Rear
Questions and Unsolved Problems for Toshiba 65HX83 65 in. Rear
Do you recommend Toshiba 65HX83 65 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I just had sky HD installed and the engineer could not get the HDMI picture up on ext 5 - just a... (More)
Answer
I've owned a Toshiba 65HX83 for 5 yrs now and keep hearing I should replace the bulb to improve... (More)
Answer
Auto focus fails and there is a strange squigely line accross the screen.
Answer
I have a 65 inch Toshiba projection TV.. we have add it for about 6-7 yrs and the focus is starting... (More)
Answer
Have smears on the screen "Plastic" Face and can't seem to remove them. Manual does not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 65HX83 65 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
