Question about Acer Aspire 3100-1405 Notebook
Jumping screen my laptop screen is jumping with white lines and causing slow reactions
    Scholar:
  • 163 Answers
A Failing inverter can cause this due to Feedback in the circuits. (Should run fine on External Monitor).. If not theres another problem.. Inverters are easy to change and inexpensive for the most part.
Posted on Jan 23, 2008
    Sergeant:
    Champion:
  • 243 Answers
Have you installed the graphic drivers for it from maker website?
Posted on Jan 06, 2008
Delayed reaction and white colors
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Acer V193w LCD Monitor
Screen is jumping and white line to the side
The brand and model number not indicated here--need that to TRY to help.
Apr 02, 2012 | Televison & Video
White line running through cente of screen
Hi there, If the line appears already from when you switch on your Laptop then it means your LCD/Screen is busy breaking. The white line is normally caused due to loose contacts inside screen and cannot really be repaired.
regards
Jul 29, 2011 | Advent Computers & Internet
A vertical white line appears on my screen
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical white line. Usually screen replacement is the only answer to fix it.
Feb 17, 2011 | Acer Aspire 4315 Notebook
Jumping and rotating screen
You might have set wrong display settings and please put the refresh rate of the screen to the optimum frequency. This will surely help you.
Apr 16, 2010 | Acer Aspire One PC Notebook
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 19, 2009 | HP Pavilion dv4000 Notebook
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Screen Replacement Problems
have just installed a new screen, all good, reset using the sleep and menu button at same time for 10secs, but the screen doesnt react to touch... no reaction at all?? just the screen safer and security code request, cant get any further?? any suggestions, thanks for your time pete
Aug 01, 2009 | Apple iPhone Smartphone
Hirizontal Lines on the TV screen
Yes your laptop will onterfere with your television if you are to close.  But it can cause no HARM?
Oct 17, 2007 | Toshiba Satellite A60 Notebook
Acer Aspire 3100-1405 Notebook Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
