Your symptom sounds like intermittent connections on the convergence IC's. Since the set is OK when you turn it on, then it goes out of convergence, it sounds to me like a ring crack in the solder connections of the IC's. I have repaired hundreds of these types of symptoms. It has to do with the heat that the IC's are generating. I would recommend that this gets fixed before the IC's go out all together. You should be able to find the IC's as they are secured to a large aluminum heat sink and they are rather large black IC's, about 1 1/2" tall and 2 1/2" wide and about 3/8' thick. If you want to repair this yourself and you have a good 45 Watt soldering iron, this is not too hard to repair. You could get a technician to come to your house, but the repair will cost between $250.00 and $300.00, but you came to FixYa for answers, you may want to do this yourself and save some money.
I hope this information allows you to resolve this issue. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed. If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYa asnowman
mitsubishi rear projection television.. 65 in hdtv medallion.. green light blinking in front of tv. ...
(More)
mitsubishi rear projection television.. 65 in hdtv medallion.. green light blinking in front of tv. Power will not turn on... I have taken off the front panel off nd disconnected the wires to the control panel... several wires. I was told that the remote would work, even with the front control panel disconnected. The remote does not turn the tv on.. now what?
ok one day we were watching it and had a surge and the power went out and now the green timer light...
(More)
ok one day we were watching it and had a surge and the power went out and now the green timer light comes on flashing but no power tried holding down reset it dont help the light is just off while im holding reset and as soon as i let go it flashes still
