Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
I have a Mitsubishi 65
By cponce4 on Nov 09, 2009
I have a Mitsubishi 65" Big Screen TV (WS-65909). I cannot turn it on. When I press the power button, the "Timer" light stays on for about 3 seconds and then turns off and nothing happens. TV does not turn on.
Best Solution
posted on Nov 09, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 885 votes
tO KNOW WHAT THE PROBLEM IS YOU HAVE TO DO THE SELF-CHECK that this model has.
After you turn it on and the power light goes off:
On the front of the TV press and hold both Menu and Input (or device) TOGETHER FOR AT LEAST 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light will blink an error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means. 2,2 is most common and the least expensive to fix.
If this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
sd tech
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
how do i manulay configure tv? i want to try this before buy chips! zenith projection rw 52
Answer
tv turns on and warms up until menu from cable comes on and tv powers itself off. What can I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
