Question about GE Profile JTP18 Electric Single Oven
No power all of a sudden, no clock, no light, no power to the ''wall'' unit mounted under the surface unit (which works fine) no breaker issue...no heated breaker, no thrown breaker...nothing..... 11 years old and always a consistant performer....???
  • nikos88 Feb 14, 2008
    I have the same problem. Since it is not the voltage issue, what are my
    options with regard to the display or relay board? How can this be
    fixed or does it need replacing?
    Novelist:
  • 130 Answers
First thing to do is pull the oven and check if there is 240 volts going to the oven. The display works off 1 of the 120 volt legs of the 240. If you have the 240 volts, then your issue is with either the display or relay board.
Posted on Jan 06, 2008
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Frigidaire wall oven
Nino,
Does the unit have enough power to run (220V), also above you only mentioned convection? So is this the only cycle you have issues with? So, bake and broil work fine? The reasons for the question are they function work together for preheat. If all you elements are having issue, then check source of power to element and relay power up at board for the issue. Did this issue start after a cycle (self clean)? Check breaker for 220V, check supply to oven 220V, check power from relay / clock for 220V. If all this is good, check the elements for 220V (use caution when doing this). Get me more information and we can solve this, I seek to locate the problem by looking for power or lack of.
I am under the assumption you understand electricity and how to work with it. If not, please seek a service person to preform these tests or repair.
Look forward in hearing back from you on the progress.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 16, 2013 | Ovens
My whirlpool oven display lights will not come on evn though teh unit has power and teh surface heaters work
What will cause that is a part on the clock that powers the display to illuminate has gone out yet the part of the clock (also called the electronic oven control) that send power to the heat elements is still working.It may work like that for years as long as you done mind the clock not displaying, OR to get it to display the clock/eoc would need to be replaced .
Gene
Aug 06, 2011 | Whirlpool Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
My wall oven's heating elements stopped working. Clock, enterior light still work.Model REG74BL*3
Sounds like one leg of the 220v ele. supply has tripped. All thats working, works off of one leg. The elements need both legs to heat. Find your breaker for the oven, reset breaker. It may look ok, but flip the breaker off and then back on. This should fix it.
Please rate solution
Sep 02, 2009 | Frigidaire Ovens
Maytag elect. wall won't bake nor broil
I suggest checking the voltage going to elements. If there is no current, trace wires. Not exactly sure if there is a fuse/relay on your model. If there is current, than the elements may have gone bad.
May 22, 2009 | Ovens
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
155 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
