Hitachi 53FDX20B 53 in. Rear Projection Television
Problem for Hitachi 53FDX20B 53 in. Rear Projection Television
Hitachi 53FDX20B - now no pic or sound
By slburditt on Nov 09, 2009
I have a hitachi 53FDX20B. Convergence was off, so i replaced both chips (store was out of STK392-150's so they sent STK392-180's). TV worked great with a DVD, but when I switched to another imput all video and sound went off. Now only the red power light blinks off and on when switched on. You can hear the set "turn" on and off, just no pic or sound.
Any ideas?
Best Solution
posted on Nov 09, 2009
Very Helpful)
Chu3505
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 85%, 423 votes
The Convergence chips it dead again,might even burn somethings else in ur tv now?Never replaced anythings more or less tolerances in electronics or machanicals equipments only same parts same tolerances.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 24, 2009
Not Rated)
Pimpinaudio
Rank: Wiz  Televisions & Videos  Expert
Rating: 91%, 15 votes
STK392-110's can be replaced with either the origional IC's or STK392-150's or STK392-180's. the only difference with these IC's is the power handling thresh hold, they do not "take more power" than origionals, they will simply last a bit longer due to running at a slightly cooler temp. check for jumped solder connections between pins, burned or dead resistors and leaking condensers, also some soldering paste or flux is conductive and should be cleaned prior to powering the machine, this can easily be cleaned with a mixture of about 80% Isypropyl alcohol and 20% acetone, this mixture evaporates quickly and will not damage electronic components, simply dip a bristle paint brush and shake off any dripping solution then set the convergence board vertically on a cloth or towel and brush the soldered joints thoroughly until paste or flux is no longer present, usually takes about 5 mins. Also be sure a heat conductive silicon was used between the IC's and heat sink, failure to do so will result in damaging these IC's and possibly the power supply. If none of the above correct the issue, diagnose the power supply. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 53FDX20B 53 in. Rear
Questions and Unsolved Problems for Hitachi 53FDX20B 53 in. Rear
Do you recommend Hitachi 53FDX20B 53 in. Rear Projection Television?
Answer
Answer
just got this tv from a friend. he couldnt get it to work and im having the same problem. i cant get... (More)
Answer
I have a Hitachi 53fdx20b picture loked like 3d..replaced both convergance chips and checked... (More)
Answer
my picture comes out kind of bended like bended line on top and bottom and the screen it kind like... (More)
Answer
I have a 60+ inch Hitachi rear projection 1080i 1 HDMI port. The HDMI port is not working, is there... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 53FDX20B 53 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
