Question about Sharp VC-A410U VCR
Blue Screen My VCR shows a blue screen when you press the Play button. It shows the video picture with FF, RW, and pause though. Can this be fixed? Thanks!
  • 579 Answers
That means you need a cleaning. Unscrew and take off the VCR cover. See the 2 (maybe 4) little windows on the outside of the cylinder head? (round metal thing on a tilt that spins) Those are the video heads and are very easily clogged with contamination causing loss of video. Take a piece of leather the size of a postage stamp, wet it with a little alcohol and just hold it on the side of the cylinder head while you spin the cylinder gently with the other hand to GENTLY wash these heads. Don't move the leather at all - especially up and down as the heads will easily break off. Let them dry for a minute and try to watch a tape. May need to do this several times to get a good picture. Can squirt alcohol directly on the heads and really soak them if needed. Last resort is to use something really strong like acetone, but beware this will also melt any plastic parts it touches.
Hope Ya Fix it!
Posted on Jan 06, 2008
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
When I play tape I only get a blue screen and no sound. While in play, if I press FF, or Rev, as I let go of the button, I get a quick clear shot of what was recorded, then blue screen again. Same thing if...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 21, 2011 | Sony Hi8 CCD-TRV138 Camcorder
I dropped my DCRTRV250. It landed on the lense/cover corner. Since then I can not play or get a video picture, just a blue screen. I can hear and feel the motor turning the video tape. In fact all the...
am sorry for you,but probably you will have to go for a qualified tech for this problem i got a idea about what hapen inside the camera when she land down
your ccd as been damage and its come whit the lens ***'y ,that an hours jobs about to fix that
and dont try to do it your self its verry touchy.
Feb 25, 2010 | Video Cameras
My vcr powers on but won't play or FF or RW. Only ''pause'' works and shows a picture. I just bought it used, but they said it worked before.
It sounds as if the motor is not operating the clutch mechanism to turn the take up spools. If you have just bought it I would take it back to the seller & ask them to show you it working or get a refund.
Aug 09, 2009 | Sharp Televison & Video
No remote for set-up
you should purchase a universal remote.
Feb 11, 2009 | Televison & Video
No picture
Lately I cannot get a picture when I turn on the DVD operation--the TV screen, as always, is on INPUT (Extension).....the unit show PLAY, but the picture does not appear--and the TV screen stays blue! The audio is on, but no video....
This is something rather recent. However, if I unplug the electric-power source for the DVD-player, then sometimes the picture does appear, though not always.
I have checked the manual but find no good answer there. Please let me know what to do....many thanks.
Aug 06, 2008 | GoVideo DV2150 DVD Player/VCR
Won't play tapes, just stays on the blue screen
ok. what you need to do it hit the side where the tape goes in...start out slow and then gradually hit harder and harder...not too hard though...because it sounds like a hardware jam...you need to unjam it by shaking it up a bit.
Jun 28, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Sound but no picture
chances are the scart lead has come out slightly at either end, give both ends a wriggle while on play
Oct 05, 2007 | Philips VR550 VHS VCR
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Sharp VC-A410U VCR Logo
227 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
