very bad odor when you open the doors. have cleaned it top and bottom, inside and out. It is still there. The refrigerator is side by side with ice and water dispenser. Could the odor come the water line?
The odor is coming from your drain pan under your evap coil. This is very ahrd to get to. They make a product that you can set in you fridge and let it run and it will take out odors. Google Refrigerator odors and it will take you the site that will ahve the product. rus
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thank you so much.....
" - cece2be
Popular Solutions for Hotpoint HSS25GFP Side by Side
Model HSS25GFPHWW does not work, freezer or frig. Replaced main circuit board nothing changed. Light...
(More)
Model HSS25GFPHWW does not work, freezer or frig. Replaced main circuit board nothing changed. Light buzz sound off and on and light on freezer door flashes.
side by side ice and water in door making growling noise at ice maker had to replace water line...
(More)
side by side ice and water in door making growling noise at ice maker had to replace water line water was off but icemaker was not when i turned water back on after about 1 hour it started making intermittant growling noise
Have fridge on as high as it goes will not freeze and fridge part is not that cold. We lost power...
(More)
Have fridge on as high as it goes will not freeze and fridge part is not that cold. We lost power and now it's not working, any ideas?
The ice dispenser flap keeps opening and closing on its own. It does so without pressing the...
(More)
The ice dispenser flap keeps opening and closing on its own. It does so without pressing the dispenser. Its almost as if someone is pressing the dispense lever to get ice or water. When this happens, you can change the setting from ice to water then back to ice then you can press the dispenser and the flap will retract back to its normal closed position (momentarily). After about 5 minutes or so, it will start opening and closing again.
