Home | Princeton Digital | VL1918 (Black) Monitor | My Princeton monitor VL1...
Princeton Digital VL1918  Monitor
Problem for Princeton Digital VL1918 (Black) Monitor
My Princeton monitor VL1918 keeps blinking on and
By eben161 on Nov 09, 2009
My Princeton monitor VL1918 keeps blinking on and off. What is wrong
Solution #1
posted on Nov 09, 2009
Not Rated)
12fixlouie
Rank: Guru  Computer Hardware  Expert
Rating: 97%, 40 votes
eben161, you might try replacing some "electrolytic filter capacitors" on the "switch-mode-power-supply" printed circuit board. Try to obtain new ones that have temp rating of 105 deg centegrade. remember to replace them + to + and - to - !!! don't screw it up!!! here are some of the values you will need to purchase. 470micro farad (uf) and 2200uf and all should have a voltage rating no lower than 35vdc please report back with the name of the manufacturer you find on the original "failed" ones you remove from the unit. even if they don't look bad (swollen, leaky) replace them all with new one's. If you won't do the work you can also check to see if Princeton can swap you a refurbished unit for your old+cash. But first you should read all the posts that have been written on this model lcd monitor and how they were fixed! I'm 12fixlouie If this response was helpful to you, please rate it on fixya. Bye for now.
Was this helpful?
Yes
No
Popular Solutions for Princeton Digital VL1918
Questions and Unsolved Problems for Princeton Digital VL1918
Do you recommend Princeton Digital VL1918 (Black) Monitor?
Answer
Answer
turn on power monetor flashes off on off ect also how do i install
Answer
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase... (More)
Answer
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of... (More)
Answer
Princeton VL1918. Speakers stopped working. Check all connections. Other functionality is OK.
Answer
The Mac Mini that it's attached to is generating a proper video image, since I can mouse and click... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Princeton Digital VL1918 ...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
