Question about Toshiba Satellite P35-S609: Pentium 4-3.2 GHZ, 512MB RAM, 80GB Hard Drive, DVD-RW/CD-RW, 56K Modem, Network ... (SATELLITEP35S609PENTIUM) PC Notebook
Toshiba p35-s609 laptop
The screen does not come on. If I tap the little rubber shut off located at the back left top of the keyboard the screen lights up and then goes off. If i keep tapping the screen wiill come on and stay for a few seconds and go off again. If I plug in a monitor I can use the laptop.
  • mariosapet Jan 06, 2009
    I have the same problem. The image is visible behind the black screen, and I also can connect an external screen and work as usual. I am told it is a faulty screen bulb, but I also read about a possible faulty mother board, switch, etc. Can the bulb be tested? What is the bulb number? How can any of the above be tested? Thanks!
I also had the same problem. I replaced the Inverter for $13 on eBay and it took all of ten minutes to install. My daughter is using the computer right now.
Posted on Jan 15, 2009
  • 81 Answers
Sounds like you have diagnosed your own problem to me. Its not the video card or you wouldn't be able to use the monitor, so it has to be a bad switch. If you can remove the bezel covering the switch you my be able to spray some contact cleaner into the switch and get it working again. Removal of most bezels starts with removing the screws on the back side of the lid hinges and lifting the bezell until it un-snaps from the housing.
Good luck. let us know how you make out.
Posted on Jan 06, 2008
Vertical lines on my screen
If after rebooting, they are still there, try an external screen. If the fault shows up on both, you have a GPU issue, if not you have a screen issue.
Dec 25, 2013 | Toshiba Satellite P35-S609 Notebook
Display shows only half screen. Other half is ok. The bad side is just vertical bars top-to-bottom. Thanks, Jim
This indicates a bad LCD screen, Hook a external monitor to the video output on the back of the laptop, If okay! the display on the computer is bad and will need to be replaced, "costly" Now! if both screens show the same problem, it is the Video Graphics Card that is apart of the motherboard that is the issue, It will need a computer technician to address this.
Jan 16, 2011 | Toshiba Satellite P35-S609 Notebook
My laptop is having a grey vertical line.
That sounds like the screen is failing. You can check it by plugging your laptop into an external screen. If the problem is still there, the laptop has a fault, if it has gone, your screen is faulty.
Dec 28, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
Good luck Hope that helps
May 21, 2010 | Toshiba Satellite P35-S609 Notebook
My toshiba Satellite P35-S609 started not charging. The charge connector seemed not working. I gave it for repair, and the person told that one module which connected the charge chord to the mother board...
Seems a bit odd that the inverter would fail immediately after a repair job that involved the power jack since the inverter is built into the screen housing or lid leaving only a single connector to disconnect then reconnect (aside from the wifi antenna wires) If it is a back-light you can shine a flashlight on the screen in a darkened room and you should see faint images. Use an external monitor to narrow it down to an inverter or perhaps a plug that had not been properly inserted (white one coming from the screen, center above the keyboard) If the external monitor does work then the problem most likely exists after that white connector if it has been inserted properly and has not been otherwise damaged during the repair process previously undertaken. Good Luck!
Jan 22, 2010 | Toshiba Satellite P35-S609 Notebook
Half of screen flickering
Yes, the probability is that either the circuitry that drives the screen, or the screen itself is on the verge of failing. It is also remotely possible that the backlight is failing. In either case, the likelihood is that a screen replacement is in order. Take it to a computer shop that specializes in Laptop repairs - or call Computer Geeks.
Sep 22, 2009 | Toshiba Satellite P35 PC Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Vertical lines in my laptop screen
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
Computers & Internet Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
