I want to remove a 10-ft wall in my basement to open up the finished den to an unfinished storage area to create a billiard room open to the den, but I discovered it is a load bearing wall in between the two rooms. How do I support the floor joists above to have an attractive open look? Can I use structural columns, or do I have to use beams to hold up the ceiling?
The floor/roof loads above will be a bigger unknown than the ceiling itself. The wall MAY be replacable with properly sized beam/column combinations but you will need to have a design professional look for adauate footing size, calculate floor loads (and roof loads if any), and size the beam/column system to support ALL of the loads now carried by the wall. If you have access to the origional floor and roof framing plans they will be a great help, otherwise someone will need to do some investigating to make thoes design judgements.
In 23 years working as a building inspector I'v seen way too many structural problems caused by inadaquate beam installations, Its worth the time and money to do it right.
Good Luck.
Just replaced the time chain and serviced the head for a 1986 Toyota Pick up SR5 22R - 4 cyl fuel...
(More)
Just replaced the time chain and serviced the head for a 1986 Toyota Pick up SR5 22R - 4 cyl fuel injected. The car starts but does not idle well and there is excessive carbon build up on all the spark plugs. Any help you can offer will be greatly appreciated. Russell Austin, Tx
