I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
After replacing battery on my Timex Expedition, the watch does not display time. If I press any of...
(More)
After replacing battery on my Timex Expedition, the watch does not display time. If I press any of the side buttons, I get 745007 to display momentarily on the face. I'm guessing I need to reset the movement. Where do I touch the movement to reset? That little dot is not very descriptive and I do not have my watch instruction sheet.
