Just borrowed my friends laptop a Dell Inspiron 1720, it was working absolutely fine yesterday, came to start it today and nothing is really happening...
Yesterday when u pressed the power button it iluminated the side indicator lights all flashed and it was fine, today if u press the power button it doesnt light up but the side indicator lights do and you can hear the machine buzzing and whirring as if it would start but thats it....
also interesting if you press the home button thats next to the power button it does the same thing,,,,,,
Sounds like the High Voltage part of the screen may have been dammaged. (easy to break part of laptops) I've done that to two of my past laptops. Does it sound like it's loading up and doing things normally. (other than not displaying the screen)? Could be that you've inadvertently place the Video Output to External and not Internal or Both, or Automatic. Try pressing the Fn (Function; unique to laptops) and tap a similar text colored button that looks like a monitor slash screen. (See picture) This procedure will cycle the Video Output through, laptop screen, external display, auto, both displays. or something similar. At any rate, by taping it at least five times, it should come up with laptop screen at least once. Try this, if it dosn't work, plug a regular vga monitor to the output on the back and see if cycling through the display types works. If so, it may be a dammaged laptop screen, if not, the battery could be low, or the power supply cord could be dammaged. Trying this is nondestructive and may be the simplest solution. Cheers, Richard.
laptop wont power up. Took battery off - unplugged it from wall. Can see that the power cable has...
(More)
laptop wont power up. Took battery off - unplugged it from wall. Can see that the power cable has green light. Laptop wont do a thing....
when I try to turn on my dell inspiron 1720 all that happenes is the blue indicator lights come on...
(More)
when I try to turn on my dell inspiron 1720 all that happenes is the blue indicator lights come on except for the middle light which flashes between 43-45 times and then it powers off
