Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive
Problem for Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
I have Seagate's Freeagent Go 250 GB external hard
By meshuggah12 on Nov 09, 2009
I have Seagate's Freeagent Go 250 GB external hard drive. It was working well until recently I was downloading a song and again and again there was a error message something like $Msft chck disk utility. After this error some of my folders disappeared. I ran error checking provided by windows and everything was alright until again the whole folder doesn't open it says folder unreadable or corrupt!! What should I do?
Solution #1
posted on Nov 10, 2009
Not Rated)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1266 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Dreadman1
Rank: Apprentice  Computer Accessories  Expert
Rating: 0%, 0 votes
How to recover files when the drive does not open? Hard drive was removed accidentally.
Was this helpful?
Yes
No
Solution #3
posted on Nov 09, 2009
Not Rated)
mashup1
Rating: 47%, 6 votes
FORMAT THE DRIVE U WILL LOSE THE STUFF ON IT UNLESS U CAN RUN A RECOVERY PROGRAM
Was this helpful?
Yes
No
Popular Solutions for Seagate FreeAgent Go 250 GB
Questions and Unsolved Problems for Seagate FreeAgent Go 250 GB
Do you recommend Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive?
Answer
Answer
Why do I get all these files in my Recycle bin every time I boot up with the FreeAgent External... (More)
Answer
my freeagent go no longer backs up. it just tells me the backup failed and when i view the back up... (More)
Answer
Not recognizing anything that I try to back up...like pictures, music...anything
Answer
Seagate Freeagent 250Gb go mac does not work on my Xp pro operating system but works fine in Vista.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
