Question about E-Machines eMachines Desktop PC
My e machine computer
When i turn my desktop on the moniter reads check your pc or pc cable. the moniter is on and working
  • Loteck May 11, 2010
    Is your graphics card good?
  • 36 Answers
Check the VGA cable - it's usually a blue head, and connects to your PC. Sometimes one or more pins can get bent out of position and cause the monitor to not function.
To fix this problem, simply grab a set of needlenose pliers and reset the pin to its proper upright position. This will take some muscle energy, but does not need to be perfect, as the pin will straighten out fully once re-plugged in.
Posted on Jan 06, 2008
SOURCE:
When i turn the power message on the moniter reads moniter going to sleep
first one you can chenge keyboard.if laptop insert external keyboard.
Sep 11, 2010 | E-Machines eMachines Desktop PC
My emachine computer was working then just stopped, when I tried to turn it back on. the moniter is showing no signal received. I have tried checking the VGA connection, changing it out for another, no...
Try your monitor on another machine - if it is working you have operating system/hard drive/motherboard/memory/heating problems. You must work that out if the monitor is good.
Apr 01, 2010 | E-Machines eMachines Desktop PC
Not reading monitor
please isolate the monitor. try using other good monitor and plug it into your desktop. if the monitor you use doesn't display it means the video card adapter is defective. you have to replace that one. otherwise vice versa.
Mar 27, 2010 | HP Compaq DC5800 Small Form Factor PC...
My computer says no signal
Check you rmnitor data cable from CPU its not connected
Oct 05, 2009 | E-Machines eMachines W2686 PC Desktop
My emachine moniter keeps on displaying self check , check your pc and signal cable , moniter is working.
There is a problem with your video card / and or motherboard usually when you experience a problem like this.
Open the case, remove the video card from the motherboard, re-install it.
Let me know what happens and we'll go from there.
Feb 24, 2009 | E-Machines eMachines Desktop PC
Moniter
First please check whether the Monitor powering ON or not
the see the colour of light of the monitor i.e, its green or orange or not glowing next see that all the lights showing but constantly flickering or else just see u r VGA or DVI Cable which is connected properly to the CPU if it is ok then remove the cable connect only the monitor to different machine in case still not comming then finally it is a monitor problem or else just check all the connections inside the CPU
In case its monitor problem either it will not power ON or else all the lights will blink constantly that means the refresh rate or the Resolution of the monitor has been changed in case if it is done just connect a different monitor boot in the safe mode by pressing F8 button after entering there change the resolution which will be in the display properties apply and reboot the machine or else turn off u r PC and connect u r Old Monitor and Boot the Machine
Jul 30, 2008 | E-Machines eMachines Desktop PC
No Display
Turn off the power and uninstall the RAM and reinstall it.Then boot the computer.
Oct 25, 2007 | Computers & Internet
Compaq FP 5315 Moniter
Have you checked the computer bios?
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
  1. Turn on the computer and press the keyboard key that enters the BIOS Setup screen key when the keyboard light comes on. The key to enter the BIOS should be one of the following:
    • HP and Compaq desktop computers that came with Windows Vista, press F10 .
    • For HP Pavilions desktop computers that came with Windows XP or previous versions of Windows, press F1 .
    • Compaq Presario desktop computers built after 2002, press F1 .
    • Compaq Presario desktop computers built prior to 2002, press F10 .
  2. Wait 5 seconds.
  3. Press the F5 key to restore the default settings of the BIOS.
  4. Press Enter to accept the change and wait five seconds.
  5. Press the F10 and then the Enter key to save the changes and exit from the BIOS.
  6. The monitor should now display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
  7. If a BIOS update was not available or the monitor is still blank, continue to the next step
Reseating loose internal components
If the PC case was recently serviced or moved, a card, cable, memory module, or processor may have become loose. When this happens, the PC might make a beeping sound when turned on. Use the following steps to check for loose components: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. With the power cable removed press the Power button on the front of the PC for 5 seconds.
  3. Remove the screw(s) that retain the panel or cover from the rear of the PC. c00371492.jpg
  5. Gently press down on the outside edges of cards and memory modules that are inserted into the motherboard to better seat them. Do not press too hard.
  6. Gently press down on the connectors of the flat ribbon cables to seat them.
  7. Replace the side panel and screw(s), reconnect the PC cables, and turn on the PC on.
  8. If the monitor still displays a black screen, the video hardware may be faulty and needs to be replaced or serviced. If the monitor displays the first startup screen but does not display Windows, continue to the next step.
Try this and if it doesnt work. please post again.
Oct 21, 2007 | HP Compaq FP5315 15" LCD Monitor
E-Machines eMachines Desktop PC Logo
24 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
