Question about Philips MC-70 CD Shelf System
3 CD shelf changer fault
The 3 CD shelf changer on our unit has developed a mind of its own and opens, shuts and shuffles at ramdom. It somentimes settles down for a short time if unplugged. I have read that this is a common fault to do with a software bug. Do you know if this is true and what the fix/cost is please?
3 Suggested Answers
SOURCE: FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well.
Posted on Jul 12, 2007
Hi! to open locked cd i torned power off then pushed button "display" obout 3-4 sec. until u see "demo mode off" now u can open cd
Posted on Jul 30, 2011
How do you open up the Panasonic SCAK22 unit ?
Five disc "carousel" changers often do not have a long service life.
Jun 18, 2014 | Sharp CD-BA150 Shelf System
The cd holder wont open
There's a possibility that the somewhere within the CD changer's mechanism there is something jamming the gears which allow it to open. I remember there was one time the CD changer wasn't opening and it turned out a cd was under in the CD changer's mechanism and I have no idea how it got there. In order to fix your problem you'd most likely have to open the unit and take the CD changer out but don't be afraid, opening and operating on this system is pretty much straight forward.
May 14, 2014 | RCA RS2663 Shelf System
I have a Phillips MC/50. The CD changer keeps changing and won't play, just keeps flipping. If you use the tuner, you still hear the clicks of the CD changer. You have to unplug it.
There is a switch inside the changer that will not release. Most likely the plastic stop it rides on has broken off . This is common when the changer keeps shuffling the disc all the time
Dec 18, 2010 | Philips MC-70 CD Shelf System
Cd door not opening
it might be a sticky mechanism inside the unit. open it up spray a little WD40 on to the tray mechanism and should work (protect laser while doing it). A REPAIRER WILL STILL FIX THE UNIT EVEN IF IT HAS BEEN OPENED
May 07, 2010 | Technics SCEH790 CD Shelf System
Sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Jun 24, 2009 | Sony CHC-CL1 CD Shelf System
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Dec 05, 2008 | Audio Players & Recorders
Need help opening my CD changer?
When you turn on the unit, pushing eject or the open/close button should work. If it doesn't work then the unit is not working. See if you can send it back.
Nov 17, 2008 | RCA RS2025 CD Shelf System
My rca 5 disk vertically stacked cd changer is stuck. Won't open. How to fix it?
Try this... unplug the unit and turn it upside down.  Have a small screwdriver ready.  No plug the unit in and try to turn the wheel in the large slot clockwize.  When you see the spring clip try to grab the white plastic stop and move it clockwize.  This should eventually open the door.  It did for me.
Aug 03, 2008 | Thomson RCA Bookshelf System with 128 MB...
CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Jul 14, 2007 | Aiwa NSX-A505 CD Shelf System
Philips MC-70 CD Shelf System Logo
53 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
