Maytag Neptune FAV6800AW Top Load Washer
Problem for Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AW 27
By chandler_wes on Nov 09, 2009
Maytag FAV6800AW 27'' TL WASHER WON'T DRAIN WHAT SHOULD I CHECK FIRST?
Best Solution
posted on Nov 10, 2009
Very Helpful)
FAV6800AWDIY
Rank: Wiz  Maytag Expert
Rating: 97%, 17 votes
Hello chandler_wes,
Here is the Service Manual for reference. Sears Parts Direct for reference.
Are you falling in spin cycle with any error codes to the LED console display such as dc and or UC which are unbalance error codes usually related to a clutch malfunction? The error codes could also be caused by Tub Displacement Sensor failure/issue. Do you take a fail code of ND which is no drain? Try this TDS check thru the lid as a first step…. Good practice to get into to Service Mode. I'm suspect of a clutch malfunction but need more info related to error codes.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine.
You can pump out the excess Tub water with this process from the Service Manual;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
From the SM;
Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Turn off the drain pump with twith the off button or hit the Presoak key.
If the issue points to a Clutch malfunction see this post for clutch maintenance/replacement process.
Post back with an update to the error code question and if you want to put on your DIY hat.
Good Luck Rich aka dh1200s
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 12, 2009
Not Rated)
captsam
Rank: Apprentice
Rating: 100%, 1 votes
I had a similar problem. Mine turned out to be a bunch of the kid's toy currency stuck in the water pump. Download the manual online, someone posted it as a PDF. I don't remember the link, but you should be able to find it.
With the manual, you should be able to open up the washer. I don't have time at the moment to write too many details, but you lift the top of the machine up, there are some magnetic pull-tabs that hold the entire top on the machine. Once that is out of the way, there are two screws that hold the very FRONT of the machine on. Once those are removed, the entire internals of the machine are exposed. The water pump is to the lower right in the back of the machine. If you crawl through the front, you should be able to pull the two hoses off the water pump. If coins or debris are plugging up the water pump, you should be able to clear them out this way.
There may also be some debris in the drainage hose, and you'll have to check that as well. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
Questions and Unsolved Problems for Maytag Neptune FAV6800AW Top
Do you recommend Maytag Neptune FAV6800AW Top Load Washer?
Answer
Answer
My clothes are stuck in my neptune. It won't drain and the door will not unlock. How can I restart... (More)
Answer
my top loader will not hold water it keeps draning out!!
Answer
my maytag washing machine stop working totally mid cycle. I'm not getting anything when I turn and... (More)
Answer
My Neptune TL is not completely draining. I've got the tub out but am having trouble getting the big... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune FAV6800AW Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
