Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
D-Link wireless router problems
Hi we are setting up or wireless router again after not having used it for a while due to changing computers....but while we were in the process of moving we lost the disk to down load the software for the router in our move is there a place i can get JUST the down load for the hardware to make it work? or do i have to go spend money on a whole new system?
  • nicoleseaboy Jan 07, 2008
    i got the drivers ect but when i go to down load the device to my machine i get to step 3 and it just stops going it says error either cable is not connected or something else i have tried and tried
I need to find instructions to download a Apacer usb 2.0 flash drive handy sieno AH320 compressor up to 5x capacity , can anyone help me find it? new at this type of gadjet,, thanks..
Posted on Jan 06, 2008
  • 1,601 Answers
Here are your drivers, pick the version of your router.
Hi, am haveing dlink dsl 2640u .its wireless is not working always ask for the key.whe i reset the router it work fine for 2 days and it again starts asking for key.i updated the firmware...
You may need to have your computer checked as well from a computer technician because its your computer that is always asking for the network key and not the router. Once you reset your router to default settings and make use of the routers default wireless configuration, it will always stay that way. There might be a possibility that the wireless card on your computer is the one that is having a problem because it always loses the saved wireless settings from your D-Link Modem Router.
Aug 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a Linksys WRT320N wireless router connecting my PC and 3 netbooks. 3 netbooks stuck "acquiring network address" after establishing wi-fi protected set up for my BlackBerry Torch. How do I...
If your 3 notebooks were already configured with router and then you used WPS to connect your blackberry, then it must have changed the wireless settings of the router, due to which the router and the 3 notebooks are not able to communicate now and due to that, the notebooks are showing acquring network address as they are not able to get an IP address of the router.
Solution: You need to open the interface of the router and check the new wireless settings and then put those wireless settings into your 3 notebooks. You may use this link for detailed instructions, or you may also chat with the technician available for chat on that website. Check or Change WirelessPassword
Jul 10, 2011 | Linksys Computers & Internet
I have been installing the router program step by step but when it comes to searching for the router it does not detect it and it tells me to reinstall it again. What shall I do?
u can follow the instructions and try and uninstall then reinstall but personally i dont use any packaging software i just use a wired connection and setup the router...anyway here is a youtube video u can view to help setup ur router (
Jun 11, 2011 | D-Link DIR-615 Wireless Router
Changed modem need to reconnect wireless router
Changing routers can be a hassle, especially if all wireless connections are in-sync with the old one. The basic steps below in setting-up a wireless connection applies to all brands of routers. Most softwares provided by manufacturers, both computers and routers, cause problems with Windows due to incompatibility issues. We will use the Wireless Zero Configuration or the Windows Wireless Manager that comes with all versions of Windows to put ease in setting up your Linksys WRT160N.
Click the link below for proper cable connections in setting up your wireless network. It also provides somewhat a checklist on what you need for wireless connectivity.
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP.
Windows Vista.
Windows 7.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
TIPS: Is your computer slow? This might help
(for Windows only)
Mar 07, 2011 | Linksys WRT160N Wireless Router
My Dell laptop does not connect easily to d-link WBR 2310 router
2 wireless laptops are connecting. that means the router must be working properly. Only 1 laptop is not connecting.
Try to change the wireless channel on the router.
For this you will need to open the set up page of the router.
Is there any computer connected to the router ? If not then you will need to connect the computer to the router and open the set up page. Under wireless settings try to change the wireless channel on the router and see if that works.
Apr 16, 2010 | D-Link Computers & Internet
OK, I want you to remove the power and then find the little hole at rear and reset this unit, this will reset to factory, specs. Now try to reset again. You will have to re-set it up all again..Do it with a wired connection through the Ethernet port. in case you don't have a manual have included a link below... have a refresher look, perhaps you are overlooking something?
Mar 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My D-link G604T connects with WEP but not with WAP
When you change the WPA encryption in the wireless router, you also need to configure the wireless card in the computer with these settings.
Please click in this link to secure your wireless network, configure the wireless router and the wireless card in the computer and follow my instructions :-
Feb 03, 2010 | D-Link DSL-G604T Wireless Router
Problem with D-Link wireless router!
try to reset your D-link router (press the reset button of at least 1min) reseting router will restore the manufacturer default router settings.
Note: Save or write any changes you made in your router if you customize it other than using the default settings.
Nov 24, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless router
My suggestion would be to first disable any encryption on the router to make your wireless network simple first to try and troubleshoot these problems. check if any MAC or IP Address filters are active on the wireless router, you can either enter the IP address of the slingbox wireless adapter or its MAC address if you HAVE enable filtering, but again, try diagnosing without filtering or encryption enabled. Also ensure your slingbox wireless adapter has its settings set to 'automatically assign IP address (enable DHCP)' so it gets its address automatically.
May 04, 2008 | D-Link Wireless
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
249 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
