Question about Sony Cyber-shot DSC-S600 Digital Camera
Memory stick locked
Hi everyone
i have a 512 MB memory stick pro duo in my camera, i was taking snaps and the memory got full and then the camera started to flash "memory stick locked" error. i tried to delete/format the card but nothing happens and the same message is displayed. the sony handbook suggests to move the write protect tab but this card does not have a write protect tab.
what shud i do.
plz if anyone could answer this, i shall be obliged
thanks
danish
  • Anonymous Feb 18, 2008
    I HAVE BEEN HAVING SOME PROBLEM WITH MY DIGICAM SINCE I BOUGHT IT JUST A MONTH BACK.
    FIRST THE PICTURES WERE BLURRED AND IT WAS CORRECTED THEN CAME THE MEMIORY STICK LOCKED PROBLEM RUNNING AROUND THE SERVICE CENTTERS SINE I BOUGHT THIS CAMERA.
    NO PEACE OF MIND. ULTIMATELY YOU CANNOT USE IT.
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
6ya staff
SOURCE:
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I have a Sony digital camera model # DSC S75. I would like the largest memory stick available for still photos. I get confused with GM and MB. I found one for 32 GB, is that the lrgest and about how much...
I did a bit of research on this, and you're going to have to be very careful. Your camera is only compatible with the very first generation of "memory stick". That sounds like a generic term, but it's actually a Sony specification. Please take a look at the wikipedia page on memory stick, and note all the newer versions. Also note that the 'memory stick' is no longer manufactured. Here is a list of memory sizes, I agree that the Mb and Gb are confusing. Each one is double the size of the one before.
8 Mb
16 Mb
32 Mb
64 Mb
128 Mb
256 Mb
512 Mb
1 Gb
2 Gb
4 Gb
8 Gb
16 Gb
32 Gb
64 Gb
Now, you will have to find a genuine Sony "memory stick" and not the Pro, or Duo, or anything like that. When they were manufactured, the largest one was 128 Mb, so that is the limit for your camera. Anything in "Gb" or Gigabytes cannot be a memory stick. I did find 128Mb memory sticks on Amazon. The review page on DPreview will tell you how many pictures you can store on a card half the size, just double it.
Feb 10, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
How do i download from a san disk memory stick pro duo - 512 MB? the stick itself is way too narrow and short. help?
Aluratek AUCR200 Card Reader
Please gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Mar 14, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory Stick error
Hello!
Following types of memory sticks are compatible with the Camera model DSC-V1:
Memory stick: 32/64/128 MB
Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
Mark 2 Memory stick Pro: 1/2 GB.
However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
Aug 22, 2009 | Sony Cameras
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Apr 06, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick fails
yes, it had failed. go for new one
Dec 08, 2007 | Sony Cyber-shot DSC-T9 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
61 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
john cordey
john cordey
Are you a Sony Camera Expert? Answer questions, earn points and help others
