Network configuration I am taking forever to download a movie from Utorrent. It says my port isn't open. I am afraid to change anything and Bell says they can't help me. Would you be able to help me out here? Barbara
    Novelist:
  • 101 Answers
Hi Granny!
Here is a site that will will walk your thru ever step, every clearly, even with photos.
http://portforward.com/routers.htm
Go there, find your router in the list. When you click on it, you will see a list of programs. Find the Utorrent in the list, and it will walk you thru every step. If you have any issues, get back with us, or click on Get Expert help, for live chat help.
Good luck,,
Posted on Jan 07, 2008
6ya staff
SOURCE:
How can i download a full movie?
First download utorrent client from utorrent.com website
Second install the utorrent after you download
Third go to isohunt.com or thepiratebay.org and search for movies.
Fourth download the torrent movie file to your documents folder.
Fifth open the utorrent program and click plus icon on the top of your utorrent program to add your movie file. And just click ok and wait to finish the downloading file. Good Luck
Nov 13, 2010 | Systran Home Translator 6.0 World
Where can i download karate kid the movie for free without any survays
download a small software, UTORRENT, from utorrent.com , then install it, then open it and there will be a search portion on the right top corner, write the name of anything u want to download for free. it will take you to some sites to select, inside the sites you select the file and download it, it will not be the original file but the torrent(image or address) of that file you are searching. open the UTORRENT software and open the tab 'file' and select 'open torrent', give it the place where you downloaded the torrent of that file and it will start downloading that file for you for free. Look like a boring or lenghty process but when you will use it for few times, you will never buy a cd for anything :)
Sep 14, 2010 | BestFreeToolbars Movie Downloads Toolbar
Slow downloading speed
Make sure that your port is open on your router to allow the connections. This setting is under the options in the software. You can follow this from the site to walk you through:
http://www.utorrent.com/documentation/connection-setup
That will allow you to connect to more peers. Also, make sure you have more seeders in the swarm. Good luck!
Oct 22, 2009 | SENAO High Power 200mW USB WiFi 802.11bg...
I need to open a port to use utorrent
first u download a software called ultra surf from anywhere on the net...then this software will search for most suitable port and it will open it for u...
OR
simply u can change the port no. between ' 6880-6889 ' in the preference option in utorrent....I think this will solve ur prob...KSHITIJ
Jun 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
When i try to download a movie on utorrent it says that the port is not open what do i do to download movies.
try to disable the security programs like norton, mcafee what ever you have on your computer and then check if it works. If it does, give access to utorrent as its a download software and firewalls always try to block downloads
Jan 27, 2009 | Computers & Internet
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Open Questions:
Computers & Internet Logo
277 people viewed this question
Ekse
Marvin
Marvin
