Question about Star Logic 17" LCD Monitor
Red screen? My Starlogic 19" flat screen has suddenly developed a red tint. I've been using it for about a year -- running it off my mac laptop without problem.  I've tried fiddling with the settings including the red tone, but it only gets worse. Any ideas?
  • Wolfplayer Jan 06, 2008
    I have the same problem with my 19 inch compaq FP 7317, itll be red like this for a day and than itll just decide to flicker back to normal colors. Ive too tried fiddling with color and adjusting gama, contrast and brightness but there is still that noticable tint. Ive also tried to change the refresh rate of the monitor which didnt work either.
  • 180 Answers
If the vga cable nicely connected may be the logic card in the LCD.
Posted on Apr 20, 2008
Syncmaster 912n red tint problem
A red or pink tint on LCD monitors indicate that the back light florescent bulbs are about to go out. Just like on regular florescent these bulbs are just much smaller but burn out just the same. Check the date on the back of your monitor, if it is less than 3 years old then its still under warranty but if its not then its time for a new monitor. The bulbs can be replaced but it really is not worth the trouble.
Feb 09, 2012 | Samsung SyncMaster 912N 19" Flat Panel LCD...
The colour has suddenly developed a green tint to the picture which I am unable to adjust The model is LE37R87BD
A green tint to a tv means it's lost its red channel (may additionally be blue channel). Check that your video cables are connected fully. If that's not the culprit, and changing tv settings doesn't work, you'll need to take it to a repair shop; so they can repair the "red circuits:" Note: there aren't any "red circuits" per 'se, but there are circuits that tell the various computer chips - in the tv - how to handle the image. By "red circuits" I'm referring to these.
Sep 05, 2010 | Televison & Video
Apple laptop screen is tinted red
Screen is failing. I have an Ibook that starts pink but it goes away, it's been like that for 6 months.
May 20, 2010 | Computers & Internet
Starlogic 19" flat panel screen won't show anything.
Have you made sure that all the cable connections are screwed in tight?
You could also remove the cable to make sure that none of the pins have become bent out of place.
Sep 11, 2009 | Computers & Internet
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
My external monitor suddenly has a blue tint
Try a different monitor, if it is OK then your 19" monitor is faulty or the video cable is faulty.
Apr 06, 2009 | HP Compaq Presario F730US Notebook
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Star Logic 17" LCD Monitor Logo
173 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
jd83854
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
