Question about Vacuums
How to send g3 sweper to factory for refurish
My g3 needs total restoration. drive transmission is noisy, cord is cut, handle coming apart, etc does the factory still rebuild these machines?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Absolutely!! If youre the original purchaser of the machine, the rebuild program is available for your kirby for as long as you own it.
here's the site for more information
http://www.kirby.com/Portals/0/rebuild_program.html
Its quite a warranty on Kirbys...wish my car had the same sort of warranty
Posted on Jan 07, 2008
6ya staff
SOURCE:
My Kirby zip brush will not spin. I cannot take it apart, any hints?
No bearing inside only brass pivot, zip brush turbines get jammed because of hair getting trapped between the two blades, simply remove top holding plastic cap, it come into 4 pieces. lay out in order cut hair off spline and re assemble
Jul 13, 2016 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
How do I tighten a handle on an upright Kirby vacuum?
Your question isn't specific enough. The upper handle grip has a bolt through the upper cord wrap that can be tightened. The lower handle has 2 bolts, but they rarely get loose. If you're concerned with the way the handle wobbles side to side at the base, that's normal. If you want a better diagnosis, take it to your local vac shop to have it looked at.
Feb 19, 2015 | Kirby Shampooer Shampoo Hose G3 Ultimate...
How to replace cable cord
You will need to remove the screws where the cable enters the rear of the vacuum . You will notice the cable is retained with a small plastic clip , remove this clip, unscrew the cable cut out the damaged section and reconnect. Ensure retaining clip is replaced. Now put the screws back into the machine body,
Apr 26, 2014 | Miele S7210 Bagged Upright Vacuum
Switch on but no power
First thing to check is to see if the cord has a broken wire, either at the plug or where it enters the vac. Frequent flexing of the cord often causes one of the inside wires to break. If where the wire enters the vac you can take apart the handle, cut off the bad part and re-wire the cord.
Mar 14, 2014 | Oreck XL Ultra Bagged Upright Vacuum
I need to replace the cord on an older Hoover upright, model S660, about 1986 vintage. The cord broke where it enters handle. Handle comes apart easily. Just not sure how to pop the switch out without...
check ebay. those vacuums are worth fixing. I loved them. they would **** the carpet off of the floor! those cords aren't hard to replace.just remember the way you got the old one out.
Aug 12, 2010 | Vacuums
My Kirby G5 has stopped working, last few times it was used it kept cutting out everytime the handle was moved??????????
This definitely sounds like your cord is bad. The reason that I specifically think that it's your cord is because the cord is actually connected into the handle, and is attached to the handle in the back. This would make sense why the machine was cutting off every time the handle was moved.
Also the cords are notorious on Kirby's for going bad, and are usually the only thing that goes bad on a constant basis.
Here's how you can check to see if your cord is bad or not:
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums2_bing.gif I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
GoVacuum.com
Apr 14, 2010 | Kirby G5 Bagged Upright Vacuum
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
On-off switch is stuck on
on the back of the handle down below the grip you will see 4 screws take them out.then slide the handle out towards the back.on the sides of the handle you will see small notches those are the snaps the hold it together.the handle will come apart.feel free to call me if you need help i don't charge just like to help people save money.if there is a cord cradle there you may have to take that off also,held onby 2 screws.314-628-9153
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
