Question about GE Monogram® ZET3038 Dual Single Oven
Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
I have a single wall oven GE Trivection, ZET3038 Monogram trim. I've had an electrician check the wiring and had GE replace the control board, main power board, relays, and some of the inside wiring and still it does not heat. The oven powers up and all functions respond when you press the keys, but it shows 100deg and never goes up from there. The upper face plate (with the control board behind), makes a clicking relay type sound when it's removed and replaced. When it is unmounted (still connected) the oven starts to heat. I've gotten it up to 375 or 400deg this way. Obviously the panel has to be in place to really use the oven from day to day. There's nothing in the way and this seems like the only way to get the oven to heat. Otherwise it simply won't. GE guys wouldn't diagnose, they just replaced a bunch of parts which were probably fine to begin with.
If anyone has any idea what's causing this, please let me know.
Thanks!!!
  • monogramman Jan 06, 2008
    I'm not familiar with that part. do you mean thermostat? do you know the part number? I can order one if so, and I'll let you know.
  • monogramman Jan 07, 2008
    I've checked the GE site and looked at the parts diagrams. There's nothing I see there called a Thermistor. Here's the link to their site for this model oven:
    http://www.myapstore.com/Omega/Dispatche...
    Is it the temperature ASM #253 on the diagram? Could someone please clarify?
    Also, if this part were bad, why would the oven have been able to heat sporadically? If it was bad, wouldn't it just not heat at all?
    Novelist:
  • 130 Answers
Monogramman you have described where your issue is. When you dismount the front panel you are moving the wires. If I was looking at your unit and you told me that it worked with the panel removed, I would look at the wiring between the front panel and the relay board for a loose connection. You should be able to pull the connectors ( remember to shut off the power for safety) and put a flash light on the backside of the connector. Look thru the front an you should see very little light. If you see a lot of light there is your loose connection. Or if you are careful, you can wiggle the connectors until you get to one that is causing the clicking. Hope this helps. I doubt if it is the oven thermistor as the oven heats while the front panel is dropped down.
Posted on Jan 06, 2008
  • 640 Answers
Was the thermistor that connects to the heat board replaced?this is the bulb inside the oven that monitors the heat,it should have 2 wires going to the board.try wiggling these wires and see if it starts to heat,if so the thermistor is bad.
  • anthony james
    anthony james Jan 06, 2008
    the oven t-mistor attaches to that board.if the wires of the t-mistor are damaged in some way you will have this issue.
Oven displays "Supply Open Neutral" What does
I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
Nov 29, 2010 | GE Monogram® ZET3038 Dual Single Oven
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Door won't close properly
Very common problem, when door is not closing all the way. You need to pull it out a few inches and readjust hinges on each side.
Ge monogram oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE Monogram® ZET1038 Single Oven
My GE ZET3038 Trivection Oven is completely dead. Checked 240 at the oven but nothing from there. Any tips?
I know the problem of my oven triton ZET3038 is the main logic board. Where can I by the piece?
Jul 09, 2009 | GE Ovens
Dead trivection oven by ge JT9300h1ss
This model has issues with the power input controller board, usually caused by surge following a power failure... board is $285 from GE plus $90 or so to install after paying a $100 service call. Replacment part is special ordered and generally takes a week or so.... have 2 of these ovens... ask me how I know.... LOL
May 30, 2009 | GE Profile JTP18 Electric Single Oven
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
New Wall Oven wiring
on a 220v unit you dont use the 110 ,,, connect the red and black as power and the white as ground / larry
Dec 12, 2008 | GE Monogram® ZET3038 Dual Single Oven
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE Monogram® ZET3038 Dual Single Oven Logo
352 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
