Our uni-aire reverse cycle air conditioner (model HAN-L6) is not as cold and the fan speed is not as high as it used to be. The unit is 2 years old. The internal air filter is clean. Could it need re gassing?
The fan speed could have a lot to do with the problem you are having. If the speed isn't right the a/c could ice up or not supply the proper air temp. 2 things could be happening here 1st the capacitor for the fan could be going out causing the fan not to rotate as needed This would need to have the capacitor replaced. 2nd. the fan motor itself could be going out on the speed needed for the a/c. Both problems require a tech to check them out. Good luck and hope this helped you some
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never...
(More)
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
