Question about Moultrie MFH-DGS-200 Digital Camera
Error Code 000400
I'm not able to erase the internal memory of my Moultrie Camera. When I try I continue to get the "redo" message. When I go through the trouble shooting I get error code 000400. Any help would be greatly appreciated.
  • scrapper14l Apr 17, 2008
    Keep getting code 400 What do i do
  • kgone May 07, 2008
    Can not get rid of error code 000400 no mater whar sd card I use.
I had this same camera 3 different times! I would get all kinds of crazy error codes I could never fix. My best advice is to send it back if still under warranty and they will replace it like they did mine 3 times.
Posted on Jan 08, 2008
Screen says card locked and dosn't appear to be taking pictures on auto
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 23, 2011 | Moultrie Cameras
Error code 000480, will not allow me to delete internal memory, says redo. is not recognized when it is connected to my laptop. brand new batteries & sandisk sd card. help!
Error code 000480="cam mod test/comm error...it is not communicating with SD card...may be bad main board ...get my parts from other defective cameras...Moultrie will tell you to buy new camera.
Jun 22, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My camera MFH-I-40 is giving me a message that says, "internal memory full. Memory needs to be erased". I do not have my manual. How do I erase the internal memory?
Solution 1
Go to options and look for format.
Solution 2
Move all your pictures to a memory card and free all your internal memory space.
Jun 09, 2011 | Moultrie Game Spy M45 Digital Trail Camera
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie game cam error code 1496 ?
this can't be an error code; error codes are in the format of 000000...100000=bat.test(0=pass;1=failed);020000=flash test/charging(0=pass;2=fail);003000=IR Sensor Test(0=pass;3=fail);000400=Camera Mod Test(0=pass;4-fail);000050=Memory Test.In this digit there are several codes...(0=memory ok/no sd card;5=memory full;6=SDcard locked;7=SDcard damaged;8= comms error)last digit,000006=Clock Test(0=pass;9=fail).
Are you sure this # is not preceeded by an "E", WOULD BE # OF EVENTS SINCE THEY WERE LAST CLEARED.
Ron L.
Jan 15, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Oct 05, 2008 | Moultrie MFH-DGS-200 Digital Camera
Moultrie Gamespy 200
The code means that the memory is full. Clear your memory, reset your camera and try again. You can download a manual at www.moultriefeeders.com that will help you.
Jun 28, 2008 | Moultrie MFH-DGS-200 Digital Camera
Deer cam DGS 200
I'm not able to erase the internal memory on my moultree trail camera. When it asks if I want to erase the memory I answer yes and it eventually says redo. I went through the diagnostic test and it identified error code 000400. I no longer have my owners manual and was hoping to go online to find the solution. Any help would be greatly appreciated.
lfp
Nov 09, 2007 | Moultrie MFH-DGS-100 Digital Camera
"Internal memory requires formatting."
This error message indicates that the internal memory in the camera requires formatting or is corrupt. You must format the internal memory. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a memory card during formatting may damage the card. (Formatting internal memory also erases email addresses and album names. To restore addresses and albums, see Kodak EasyShare software Help.)
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Moultrie MFH-DGS-200 Digital Camera Logo
943 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
