Question about Whirlpool AWG329 Front Load Washer/Dryer
Wont spin or turn
This sounds like ti's running , but only sends water in and pumps it out nothing else. :(
  • 121 Answers
Check the belts attached in the back you can tell if you take the panel off if so it could be your brushes in the motor or the motor is faulty
Posted on Mar 03, 2008
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 01, 2010 | Washing Machines
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
Wont spin, motor shaft turn but belt does not
If you start the washer and it just kind of buzzes and then does nothing, one thing you can check is to see if you have a clogged water pump. If you have kids sometimes baby socks can get jammed into the pump causing it not to spin, to check the pump simpy pull the hose on the back that goes into the pump and the hose that comes out of the pump, then the pump should slide off the shaft check to see if the water pump spins freely!
May 02, 2009 | Washing Machines
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fisher & Paykel no spin, no rinse
hums sound proble coming from the drain pump. sounds like its trying to pump out water but cant. try tipping back andsee if you can spin the pump manually, (usuallya fan cooling blade coming outta back end of pump.wont spin if it cant drain
Mar 22, 2008 | Washing Machines
Spin cycle
Without any other info. this sounds like the basket drive is worn out. Depending on the brand, it has different names, but it all does the same thing. Its kind of like the clutch in your car. It has to slowly get to speed. Yours, without any clothes in it has no load. But when you add weight, it doesn't have enough power to turn it. Its slipping or just worn out. Just wondering, why did you change the water pump? Did the wheel on it break?
Mar 07, 2008 | Washing Machines
Whirlpool AWG329 Front Load Washer/Dryer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
