Question about Seagate 80GB 7200 rpm SATA/150 8MB Serial ATA HD REFURBISHED p/n ST380817AS (ST380817ASR) Hard Drive
Bad sectors and fails under minor load
My hdd seagate baracuda ST380817AS AND SERIAL NO 4MRL00Z HAS MADE BAD SECTORS ABT 20 KB AND EVEN IF I RUN WINAMP OR THE PHOTOSHOP SIMULTANEOUSLY ,THE HDD FAILS TO START AND MAKES BEEP BEEP SOUND... HELP ME MAIL AT trex175@gmail.com is it under warranty ? and is it repaireable ?
  • 1 more comment
  • hard drivercrasher Jan 07, 2008
    hey i got it in jan 13 2006 dat time dealer said dat its 5 yr warranty and when i chkd now the drive is out of warranty
  • hard drivercrasher Jan 08, 2008
    MY NOS ARE MODEL NO =ST38O817AS,AND SERIAL NO IS 4MR4LOOZ PLZ CHK
    YA ITS UNDER WARRANTY
  • 62 Answers
If its not under warranty and you still want to use it, format the drive using NTFS. Use a QUICK FORMAT. NTFS has a property of isolating bad sectors so that it wont cause a problem like you had.
It is possible to fotmat it from Windows XP CD on booting from it, if you have only one drive. Also, you cando it from other computer or your own if you have 2 HDDs. Remember to backup all your required data before this.
Posted on Feb 18, 2008
    Scholar:
  • 135 Answers
You must have gotten the serial number wrong. "Invalid warranty", which is what the Seagate warranty checker gives you, does not mean out of warranty, it just means it was unable to recognize any drive with that model and that serial number. You either got the wrong model and the right serial number (unlikely as the model number you wrote is a real one) or you got the right model and the wrong serial number.
Posted on Jan 07, 2008
  • Yonatan Horan Jan 08, 2008
    Good luck getting it replaced.
    Scholar:
  • 51 Answers
No it's not repairable. Copy any data you want from it to another drive, cd, dvd, etc. Go to www.seagate.com and fill out a warranty RMA form. If it's warranty you'll get a new one from Seagate
Posted on Jan 06, 2008
  • Patrick Wagner
    Patrick Wagner Jan 07, 2008
    Thanks for trying??
    Like I can fix a dead drive for you??
    I gave you what you need, it is FIXED!!
    If it was bought in 2006 it IS under warranty. Send me a plane ticket and I'll fly down, hold your hand and fill out the form for you.
    Sheesh
Hdd seems to have bad sectors. Is this "normal" foor this HDD?
all of these usb hard drives run into these problems, especially if there is not fan inside it or if you do not "remove hardware safely" when unplugging from the usb port on the computer.
Jun 14, 2011 | Samsung (HXMU064DA/G42) 640 GB USB 2.0...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
I have Seagate HD 500GB (Internal) and my PC configuration is Intel i3 Processor with 2GB RAM, 1GB Nvidia Graphic Card and 250GB HD(Internal) in which OS is loaded. I'm facing a problems as...
Your problem is very clear... The HDD has got bad sectors in it and that is the cause for the Sneak sneak sound...
This causes your HDD to not get detected under bios in most of the situation and this is the root cause for all the problems stated above...
Here is the solution:
It is not possible to do any kind of service from your end...
It has to be sent to a seagate service center to get serviced...
Mostly they will never service the HDD, they will replace it with a new one...
All the seagate HDD comes with 5 years warranty...
you can opt for replacement...
search in google for an authorised service center located in your locality...
Dec 18, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How to find my hdd warranty??
If you want to know the warranty of your hdd then click the below link and fill the details and check your warranty
http://support.seagate.com/customer/warranty_validation.jsp?form=0
How To Find Model and Serial Numbers
If your drive is connected to your computer: Seagate has created a very simple tool that will tell you the serial number and the model number of any and all Seagate and Maxtor-brand drives connected in or to your computer. Use the DriveDetect.exe method to find both numbers.
You can also use SeaTools to display each number.
(See below if you have a Mac computer.)
If your drive is not connected to your computer: See the flash-based Serial Number locator tool to find your serial number and model number (and/or occasionally the serial number and the part number) on the drive label.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 01, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Bad Sector Failure
Simple thing is u hav to boot with XP cd
http://support.microsoft.com/kb/315265
do this procedure
May 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a laptop with HDD Seagate 160 GB. Yesterday I can't access my Windows anymore then I use a CD bootloader and check the HDD using HDDTune.Here's the result:...
You can run chkdsk /r from recovery console, it will mark the bad sectors so that the computer wont try to use them. If you bought the drive separate from the laptop you have a 3 or 4 year warranty at seagate. They will replace the drive for free pretty painlessly.
you can check warranty here: http://support.seagate.com/customer/warranty_validation.jsp?form=0
I gotta tell you, don't put files on there that you need to keep, and you would be lucky to get another week out of that drive. Check ebay, you should be able to get a 20G drive for around $10-20 to keep it running until you get a bigger drive.
Jan 13, 2010 | Computers & Internet
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate SATA Baracuda 160 GB harddrive crashed
I've found this to just be the nature of hard drives. You never really can trust them, thats why you always need a backup. Maybe look into a fault tollerant RAID solution if it's really important (kinda expensive)
Nov 23, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Seagate 80GB 7200 rpm SATA/150 8MB Serial ATA HD REFURBISHED p/n ST380817AS (ST380817ASR) Hard Drive Logo
219 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
