Question about Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner
In-op drive This drive will open, close and begin a process, but then I get a "Wrong Configuration " Code 19 Message. In the system info center, It reads ? -VxD loader in-op. In the Controll Center, I have tried to uninstall and then re-install with NO Luck. I have tried to update the drivers, and get a failed configuration message (in the registry)........"HELP"
UPDATE
Posted on Oct 21, 2008
DVD player not recognized
If your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry.
Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry.
If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option.
Click "Yes" to confirm the deletion.
Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again. Click "Yes" to confirm the deletion.
Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error.
Apr 08, 2014 | Panasonic Toughbook CF-W8 12.1-Inch Laptop
"failure using the VxD Loader"
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey.
1. Uninstall and reinstall the driver
• Click Start Orb > type device in search box > click Device
Manager
• Click arrow to expand Disk drives
• Right-click on your Iomega Hard Drive > click Uninstall
• Reboot and let Windows locate and install Iomega Hard
Drive
2. Update drivers from manufacturer website
Manager
• Right-click on your Iomega Hard Drive > click Update
Driver Software
You should take a look at this KB article about Code 19 / Code 43: http://support.microsoft.com/kb/310123
Also take a look at this KB articles: http://support.microsoft.com/kb/314060
Jun 04, 2012 | Iomega Computers & Internet
Windows vista is unable to format DVD+R and with a other burner program I get the following error: 19:17:00, File(cl_DVDData.cpp), Line(193) -> Begin burning process Current drive: <G:...
have had this problem myself and wasted many discs you need a new burner but there is a work around to this problem
just leave the disc open so that more data can be added and no more problems
Jan 05, 2011 | LG GP08NU20 DVD±RW Burner
My cd-rom drive isnt working.. this message is displayed in device manager.. Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged....
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 05, 2010 | Gateway (5500652) (  5500652)...
When my Brother HL-2140 Laser printer (USB port) all of a sudden stopped printing (or prints blank pages), I went to Device Manager to check on my hardware status. Under DV/CD-ROM drives, TSSTcorp CDDVDW...
Seems like the registry for your Dvd-Rom is corrupted. Try disabling and uninstalling the driver, then enable and wait for windows to clean install its driver.
Oct 12, 2010 | Computers & Internet
ASUS Driver wont operate
Here's a solution to fix this:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT
and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Thanks for using Fixya.
Jul 27, 2010 | ASUS DRW-2014L1 DVD±R Dual Layer Burner
I Unable to access my Laptop please help me out.
hi,
do not choose safe mode,instead choose the start normal, If still you can not load and error exist, there might be missing of your files or your files are corrupted..Format your computer and back your important files then install new (OS) Operating System.I hope this may help you.
best regards,
kaybicks
Feb 27, 2010 | Toshiba Portege 320CT Notebook
When I insert a cd in my player I get this error oe 0028:c182b573
Method ONE Disable the SCSI1HLP.VxD using the Microsoft Configuration Utility:
  1. Restart your computer, press and hold down the CTRL key while Windows is starting, and then choose Safe Mode from the Startup menu.
  2. Click Start, click Run, and then type msconfig in the Open box.
  3. On the Static VxDs tab, click to clear the Scsi1hlp.vxd check box, click OK, and then follow the instructions to restart your computer.
Method Two loadTOCNode(2, 'resolution'); NOTE: By following the steps below, any device that uses the Scsi1hlp.vxd file may not function properly or you may not be able to restart your computer. Some SCSI devices and some ATAPI devices use this file. If you are not sure if your hardware uses this file, check with your hardware manufacturer before you proceed.
Rename the Scsi1hlp.vxd file in the Windows\System\Iosubsys folder:
  1. Restart your computer, press and hold down the CTRL key, and then choose Safe Mode from the Startup menu.
  2. Click Start, point to Find, and then click Files or Folders.
  3. In the Named box, type scsi1hlp.vxd, and then click Find Now.
  4. In the list of found files, right-click the Scsi1hlp.vxd file that is located in the Windows\System\Iosubsys folder, and then click Rename.
  5. Type scsi1hlp.old, press ENTER, and then restart your computer.
Apr 04, 2009 | Microsoft Windows 98 for PC
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Open Questions:
See all Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Questions
Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
