I have tried to reinstall my Windows XP Home OS on my pc that is now loaded with Vista Business but the screen says i cannot because there is a newer Os installed
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
Windows Vista Business or Ultimate Edition
32-bit OS Installation Only
Windows XP Professional or Home Edition
With Windows XP Service Pack 2 or Service Pack 3
Not Supported:
Windows Vista 64-bit (any version)
Windows XP Professional x64 Edition
Windows XP Media Center Edition
Windows 98, Me, 2000, NT, 95, 3.1, DOS
Not Tested:
Windows Vista Home and Home Premium Edition
Although Windows Vista Home and Home Premium Edition have not
been tested or qualified by Digidesign, there are currently no known
issues with Vista Home and Home Premium 32-bit operating systems and
Pro Tools M-Powered 7.4 compared to the supported Windows Vista
Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows
Vista based on our initial limited testing and customer feedback.
Although full qualification with all Digidesign products has not been
completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do
recommend that you backup your system and create a restore point before
updating to SP1, should you encounter any problems after installing the
update.
Hi, No you can't downgrade once Vista business is installed, what i do recommend you do is when Vista business asks you for the product key, if you input "your" key for home basic it should theoretically install home basic for you as most of the install DVD's are multi installers (basic, premium, business and ultimate)
Not both. If you have the Vista recovery, go ahead and load it first, then load the XP by creating a new partition on your harddrive. Now you have a dual boot machine, and will need the XP device drivers. Not sure if you have them or not, so here is a place to get them.
you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......), you have to buy a Windows Vista CD and install a fresh copy or format.
Some Minimum Requirements:
i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only in some versions of Windows Vista)
NOTE:
"Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this can help you determine which features and edition of Windows Vista will run on your computer.
i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista will suit your system(based on you system configuration. or hardware components.) and then you can install the upgraded version of windows xp(mostly windows vista home,.........)
have you tried turning off the computer and turning it back on and tapping either F11 or F10 until it loads System Recovery and that should take you to Windows System Recovery and then you can reinstall windows. Let me know how it goes!
