Home | Heaters | My pilot keeps goi...
Heaters
Problem for Heaters
Generic problem for all Heaters
My pilot keeps going out on the fur...
By shawb on Nov 09, 2009
My pilot keeps going out on the furnace. We lite it and once the furnace reaches the thermosate temp it shuts off and the pilot goes out. I have replaced the thermocouple and a $400 gas valve. The problem still exist. Now the company says the gas company may not be sending in enough gas or their may be a crack in the furnace block. I have no more money. Please suggest what I should do?
Solution #1
posted on Nov 10, 2009
Not Rated)
adamsaire
Rank: Wiz
Rating: 92%, 11 votes
Check the pilot light size. Is it small and not surrounding the top 1/3 of the thermocouple? If it isn't then the pilot orfice is restricted or the pilot tube compression nut could be loose. The pilot gas adjustment screw may also need adjusting if this gas valve has one. These problems should only be addressed by an experienced service tech.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
What is the best portable heater for a 700 sq ft area
Answer
how can you buy things for less than what they ask for?
Answer
When turning on my Quadra Fire 1000, turn up the thermostat the orange light should come on... (More)
Answer
how do you install a 2 wire heat only honeywell thermostat?
Answer
I have a Trol A Temp MST (forced hot air) duct controller connected to HOneywell CM260 dial... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
