Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52" hd52w57
I have a 3 to 4 year old set and it has no power. The power button does not light up and it does not make any noise. Before it went out the picture got smaller and smaller and then that was it. I dont know where any of the parts are so if you have an idea please try to explain location of part.
  • hoyt2189 Jan 06, 2008
    Where would the convergence board be located for this model? (52" RCA HD52W57) I googled it but did not find location. Or would anyone have a part # for the board?
If you take the back off of the TV a, the main board will be on the bottom of the console (it's easy to spot). Th convergence chip is on this board. It is clamped into the board usually by 2 screws (one on either end).
Posted on Jan 06, 2008
  • 77 Answers
Sounds like the convergence board has gone bad. Usually this costs about $300 to $400 to repair, and takes about an hour.
6ya staff
SOURCE:
My 52" Vizio LCD (2 yrs old) has power but blank screen
Looks your power supply quit. Get a new one from vizioparts.com might cost a buck and a half,plus an hour of labor, but 52"? deffinetly worth it! Vizio is good on parts. Make sure, have your serial# ready. some sets have been modified within a year, might get a wrong part without ser#.
Take care.
Jan 23, 2010 | Vizio GV52LF 52 in. LCD TV
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 inch power light comes on no pic.,shuts off makes noise
I think you have a shorted hori output Transistor NTE2324 if it makes a low squealing sound also ck capacitor 114,120,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and other 2 are 220uf 35v.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
54 in RCA Projection
Please respond to this same post with your model number and I will be able to help you out
Jun 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
Rca tv will not power on
Check the horizontal output transistor. This may be shorted.
Mar 12, 2008 | RCA D52W19 52" Rear Projection Television
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 52" HD Widescreen
Only thing can suggest is try the bulb itself to see if it got damaged in transit.
May 22, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
