Trying to instal extra ram in Aspire 9500 laptop
Hi
Opened memory cover
the 512 card already in there is in the top.
I am probably being a total idiot here but I assume I have to remove this to allow access to the slot below? Is this a 'try and grab it between thumb and forefinger and yank it' job?
I tried to slot the new one under the existing but it seemed like I'd probably break the whole thing!
  • 56 Answers
The ram slots are stacked. you have to remove the top one first, which can be done by pressing the buttons on the sides of the ram chip, and then it should pop towards you, then you can pull it upwards and out. from there, you can take out the other chip, if there is one, or you can start installing them. installing the new ram chips is just as easy as taking them out. first, line up the slots in the chip, then push it in as far as you can without breaking anything. then push it down so that you hear it clicks on both sides, and doesn't move. then do the same with the top ram chip. any problems, just ask
Posted on Jan 06, 2008
6ya staff
SOURCE:
I have an MSI all-in-one AE1900 with 1GB RAM memory. Theoretically at least I understand it is upgradable to 2GB. I know there is no extra slot to expand but getting mixed information on whether the...
Hi lchangkee...
If you want to upgrade your ram, all you do is remove the ram that is in the computer, and replace it with compatible ram (same number) an example of that would be if your ram was SODIMM 512MB PC2100 DDR 266 512 MB LAPTOP 200pin MEMORY, then that is the type of ram you will want to replace it with but more like this.
SODIMM 2GB PC2100 DDR 266 512 MB LAPTOP 200pin MEMORY notice the only thing that changed was the amount from 512 mb to 2 gb. Most memory cards can be removed without any problem...refer to your owners manual as to where the ram is located Please take time to rate me
Aug 31, 2011 | MSI Wind Top AE1900-90SUS - Atom 330 1.6...
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a Sony Vaio PCG-K25 laptop and am trying to upgrade to a gig of memory. Is it possible to do this? I put 2 512 memory chips in the slots but it only sees 448. Using Kingston Technology 512 mb...
This laptop has its own graphics card that doesn't rely on system memory for the graphics.
There should be no reason why its not detecting all 1GB of ram that you have installed.
Open the ram cover and make sure that you have clipped the ram into place properly.
Regards.
Jul 01, 2010 | Sony VAIO PCG-K25 Notebook
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Mar 31, 2010 | Computers & Internet
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
After upgrading RAM 1G to 1.5G
The BIOS will recognize the new ram when the pc is turned on. If the amount is being reported correctly and there are no beeps you are good to go.
Feb 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Adding memory
Try re-seating the RAM. If that doesn't work ensure that your laptop supports the ram you bought. If the RAM you have is PC2700 and your computer only supports up to PC2500 (for example) it wont work.
Aug 19, 2008 | Sony VAIO FRV25 Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Open Questions:
Computers & Internet Logo
118 people viewed this question
Ekse
Marvin
Marvin
