Question about Eureka Vacuums
Eureka Altima Vacuum Cleaner w/Power Paw
Power paw does not rotate, (have cleaned and no debris is on attachment). Acutal vacuum picks up animal hair but not small debris.
  • rebecca62 Jun 25, 2008
    My power paw isn't working, doesn't rotate. I have cleaned it . thank you, rebecca nolan
  • Anonymous Nov 24, 2008
    Power paw does not spin. Checked everything, took it apart, no debris. Please help!
The way I resolved the problem was to remove the cover at the end of the power paw. Then remove the so side black covers for the shaft. Remove any debris and hair and then put back together. This solved my problem.
Posted on Nov 27, 2009
How do you replace the belt on the pet power paw vacuum
1. Pry off adjustable clear cover with flathead screwdriver.
2. Unscrew 2 Philips screws holding power paw together.
3. Place tips of needle nose pliers into the two holes on each of the black round pieces on the ends of either end of the roller. Twist and the black pieces will release.
4. Remove roller, use needle nose pliers or awl to dig out any hair wrapped up in the roller or especially the ends of the roller at the metal pins.
5. Replace belt and put everything back together in the same order you took it apart.
Mar 18, 2011 | Eureka 3276AZ Pet Lover Bagless Upright...
Hi i am trying to find a manual for my eureka power paw model 8852..but have hand no luck finding out where you can get one..any where you know of i am in great falls, mt
You can download the owners manual from below site. About midway down the page, click on "Owner's Guide" tab. Right click on "Owner's Guide" and left click "Save Target As". Save to a file dedicated to your Vacuum.
Oct 04, 2010 | Eureka Uno 2998AZ Bagless Upright Vacuum
The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
Oct 18, 2009 | Eureka Vacuums
I have a eureka power paw that keeps breaking belts. there doesnt seem to be a part that keeps the belt in place
Make sure the roller and turbine bushings are clear of obstructions (hair, etc) and spin without excess resistance. As for a lack of barrier or belt guide, make sure that the bushing blocks on either end of the roller (and turbine, but most importantly the roller) are installed identical to each other (otherwise the roller may be in on an angle causing the belt to mis-track). Possibly a part may be missing or improperly installed, but not likely. What's important to remember is Eureka (Electrolux Homecare Products) designed the Power Paw as a cheap, quick source of income to add onto their uprights to cash into the ever-lucrative market of pet owners dealing with pet hair. Like their upright vacuums, Eureka/lux know extremely well the importance of designing their product with a very FINITE life-expectancy, and hence expecting this product to be anything of a long-term or durable solution is evidence only of you having been mislead by marketing. Of all the turbine-driven tools in use today, this one is the most inexpensive, disposable I've had the pleasure of working with. I got one free when they hit the scene. I took it back to work still in the package after seeing its track record evolve.
Long-term solution if you love these turbine-type tools? (and you should, they're great and solve major issues. I own several different ones and am very attached to them as attachments!). Go to a vacuum store and find a robust, long-life version of what these little things are trying to be. They're in a higher dollar-range, but so's a Power Paw if you start replacing it every few months. Ask for one made by Wessel-Werk. German engineering, been around for decades. The made-in-china knock-offs are better than the power paw, but if you're up for it, the actual tool made by Wessel is the benchmark by miles. The only thing possibly comparable in long-term quality and durability is called a RugRat by guys in our industry, and sold by Vacuflo and Kirby and such for decades and decades now. Most vacuum vendors should be able to hook you up. :)
Jul 12, 2009 | Eureka Vacuums
Eureka 2971 vacuum
The duster on this unit is just that a duster the holder for it is to vacuum it off when your not using it it doesn't have anything to do with the vacuum cleaner really. As for the power pawl it is a air driven upholstery nozzle the suction air passes through a turbine which in turn spins the brush agitating whatever it is your cleaning ie. sofa,steps. Simply attach it to the end of the hose and your off just be sure to try and clean any hair or debris for the unit it will not work if the air flow is cut off. For any questions or parts for this unit or any other visit
Jul 30, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
1,054 people viewed this question
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
