If it passed inspection, technically the beams are aimed properly.....that is part of the required inspection.
Take it back to where it was inspected and have them correct it.
Inform them that they passed your vehicle without checking the headlights.....I'm sure they want to keep their inspection license :)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
http://repairhelpcenter.blogspot.com/2012/01/passenger-side-low-beam-out.html
Low beam HID light goes out?
http://schematicsdiagram.blogspot.com/2012/01/low-beam-hid-light-goes-out.html
----------2007 Dodge Caliber: Low Beam Headlight Not working
-------------Chevy Tahoe: Low Beam Lamps are not working?
http://technoanswers.blogspot.in/2012/04/chevy-tahoe-low-beam-lamps-are-not.html
----------2001 Chevrolet Tahoe: Both Low Beam Lamps Not Working?
--------------2002 Toyota Tacoma: Low Beams not working?
http://technoanswers.blogspot.in/2012/04/2002-toyota-tacoma-low-beams-not.html
-----------Low beam headlights Modification?
-----------DRL and Low beams not working?
http://schematicsdiagram.blogspot.in/2012/04/drl-and-low-beams-not-working.html
-----------These will help.Thanks.
