Question about RCA RT2600 System
Rca rt2600 OVERLOAD PROBLEM
At first when selecting 'source up/down' buttons on the unit it may display 'mute' sometimes as if i had pressed the mute button.
now after 2years....it turns on gives video from my dvd player then after 15sec a loud humm comes from all speakers...even if the volume is down to zero....this lasts 3secs then a louder 'bang' is heard like if someone dropped a microphone....at the same time as the bang, the screan displays 'OVERLOAD' and the unit shuts off (i.e. standby).
this happens no matter what source is on , vcr analog, dvd, digital, etc.,
this happens if no speakers are connected or not connected
this happens if dvd, vcr, etc, is connected or not connected
will admit perhaps a lot of dust inside unit.....unit was working perfectly (i.e. sound and video) before.
one night it was left on all night with my dvd off....i turned of the rt2600 in the morning,....this was the last time i remember it working before the 'OVERLOAD;' problem.
  • junglemonkey Jan 06, 2008
    sorry....in my overload problem for the rca rt2600 i said the problem occurs whether the speakers are connect or not connected.....
    the problem described is when the speakers are connected....the humming sound and the bang sound come from the speakers.
    Problem Solver:
  • 9 Answers
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Posted on Jun 27, 2008
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
Tip
Service menu codes jvc
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
-Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
Turn the TV on.
Using the remote control:
- Press the {INFO} & {MUTE} buttons at the same time.
- The Service Menu will be displayed
- Use the number keys to select the category.
- Use the {VOL+} {VOL-} buttons to enter the category.
NOTE: Some models don't have category selection.
- Use the {CH+} {CH-) buttons to select item to be adjusted.
- Use the {VOL+} {VOL-} buttons to change values.
- Press the {INFORMATION} button to exit.
Turn the TV on.
# Press {DISPLAY} & {PIC MODE} buttons at the same time.
# The Service Menu will be displayed
# Use the number keys to select the category.
# Use the {UP} {DOWN} buttons to enter a category.
# Use the {LEFT} {RIGHT} buttons to select items.
# Use the {UP} {DOWN} buttons to change values.
# Press the {DISPLAY} button twice to exit
# Press the {MENU} button.
# Select "Clock Set".
# Set clock to 3:21 AM and press "Start Clock".
# While a "Thank You" message is displayed on screen, press the {MUTE} and {MENU} buttons.
# The Service Menu will come up.
# Use {UP} {DOWN} to select items.
# Use {LEFT} {RIGHT} to change values.
# To exit, turn the TV Off.
on Apr 29, 2015 | JVC Televison & Video
Gli sound systems am-1000
test this God bless you
Jul 11, 2013 | Audio Players & Recorders
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
How do i set the clock on a pioneer deh-p4100
Press and hold the SOURCE button until the unit turns off. Press and hold the FUNCTION button, until display pops up, then release. (If you do not have a FUNCTION button, then push the AUDIO button) Press the FUNCTION button again until the clock shows on the display. Press the UP and DOWN buttons to adjust the hours. Press the LEFT or RIGHT arrows to move to the minutes. Press the UP and DOWN to adjust minutes. When complete, press the SOURCE button to exit.
Hope it Helps, if so, please feel free to comment.
Mar 28, 2011 | Pioneer DEH-P4100UB
How to set date and time on GE 6.0?
Instructions:
- Remove the handset from the charging unit. Press the "Mute" button to enter the "Main Menu."
- Use the "Volume Up/Down" buttons to scroll to the "Set Day/Time" sub menu and press "Mute" to enter it. "Monday," the default day of the week will flash on the screen.
- Use the "Volume Up/Down" buttons to scroll to the correct day of the week. Press "Mute" to select.
- Use the number buttons to enter the correct four-digit time. Press the "#" key to switch from AM to PM.
- Press the "Mute" button to save the settings and exit setup. The correct day and time will now be displayed on the screen.
or you can visit this website
http://www.ehow.com/how_6974003_set-ge-28801-cordless-phone.html
Mar 19, 2011 | Uniden Cordless Phone
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
How do you get the Pioneer DEH-P670MP car stereo cd player off of mute?
hi there
to fix this press and hold the source button till unit turns off the source button switches from CD - radio...................once your unit powers off........press and hold the function button down till the clock appears in display you should also hear a beep when this happens.........press the function button repeatedly until the telephone feature appears now switch by pressing the skip button to ATT (Attention) once this is done press the source button to power on the pioneer unit simply turn up the volume and problem should be solved......
hope i was able to help
Feb 21, 2009 | Pioneer Premier DEH-P670MP CD Player
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
No soun thru speakers
First try resetting the unit. If that don't work try this:
Press and hold the SETUP button for at least 3
seconds.
2 Press the UP button repeatedly to select
“mute”.
Each press of the UP button changes the
modes as shown:
NOTE
If you press the DN button the display scrolls in
reverse sequence.
3 Press the TUNE button to toggle the mode
between MUTE ON and MUTE OFF
4 Press the SETUP button to set the selected
mode.
→ NORMAL/HI-FI → AMBER* → DIM → SUB
DEMO ← AUX ← SCR ← MUTE ←BEEP ←
May 30, 2008 | Alpine CDA-7876RB CD Player
RCA RT2600 System Logo
607 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
