Question about GE 32GT740 32" TV
Clicking off and on sound
When I press the power button, I hear constant clicking sound like it's trying to come on but never does. Can you help?
  • 5 more comments
  • wallace3 Jan 12, 2008
    I have the same problem all of a sudden it was fine before we took an afternoon nap then all of a sudden it started doing this somone help
  • rewdey Feb 11, 2008
    same thing clicking on and off but no picture/sounds like a bad power bank
    I think this is terrible! this TV isnt even 4 years old! How bad of GE!
  • MDKern35 Apr 23, 2008
    The Television worked fine one night. The next morning it just made the clicking sound like it was trying to come on, but no picture! I have tried unplugging it for a few days and replugging it in, but same problem! Now wondering what its gonna cost to fix, and is it worth it?
  • Anonymous Jun 09, 2008
    GE 32" TV - CONTINUOUS CLICKING ON & OFF, NO PICTURE OF SOUND.
  • Anonymous Jul 28, 2008
    4 years old and it has ,out of the blue not turned back on. clicks three times when you hit the power button. i have it apart and it is a little blue box next to the fuse holder. don't know how to identify this part.
  • morgava Aug 10, 2008
    I have the same problem is there help?????? or should I be looking for a new TV
  • bsisco1 Nov 24, 2008
    My TV did the same thing just black screen and tv shut itself off. I tried hitting the power button and all I heard was a clicking sound. Also tried the unplug and plug it in same sound. Repair tech did come out but said it would be about $348 to fix. We were hoping we could replace the part ourselves. Has anyone found the part that needs to be replaced or had a tech fix for less than the above quote. Thanks Bonnie
    Genius:
  • GE Master
  • 1,689 Answers
The power supply is in the protect mode. There is probably a short in one of the areas on the circuit boards. It is also very likely that there is a scan failure. The set would have to be properly troubleshooted to determine that exact failure.
Jerry G.
Posted on Apr 20, 2008
Why does the sunroof on my bmw not close ?
It might be the sunroof switch that needs resetting,
Press open and keep button pressed till you hear a clicking sound, then press close and keep button pressed till you hear clicking sound that should have reset the switch.
Jul 26, 2014 | 2004 BMW 320d Touring
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
I turn the key and I hear constant clicking and neutral light flashes. when I press the start button it stops clicking and does nothing help me
Sounds like loose battery cables to me. make sure they are clean and tight and battery is fully charged.
Jan 05, 2013 | 2000 Yamaha YZF-R6
Constant clicking sound when turned on....no picture....looks like TV isn't on. You only hear the constant clicking. You have to cut power to stop it.....hitting the power button on the TV doesn't...
Sounds like bulb is burnt out. Have replaced its the cheapest way to go. It may be a power board but if its out of its warrenty, then you may just want to buy a new set.
Aug 02, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Aug 23, 2009 | Refrigerators
When i turn on my samsung 62'' inch rear projection tv(model#HLR6167WAX/XAA) it begins to whine like a fan working overtime, I will get a picture for about 5-8 seconds, and then it will cut off and the...
Hi.The ballast may be defective if you hear constant clicking sounds after you've pressed the power button.
If there are no clicking sounds after you press the power button(3-5 clicks every 2-3 seconds), this will confirm optimal ballast performance and, it will also confirm a major issue that concerns the Power distribution board. There are several weak or damaged components on the board that have failed.
The replacement of the power board is recommended in this case.
Jul 08, 2009 | Samsung Televison & Video
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Why is my tv doing this?
Power supply problem. Usually caused by incorrect or missing feedback voltage...accordianman
Jan 16, 2008 | GE 32GT740 32" TV
Help
Hi there!
May be a power supply fault, Line stage, loose solder points or regulation( 5V to the CPU) to trigger switch on. If not familiar with electronics, please refer to a repair technician. Regards, JUS004
Jan 12, 2008 | GE 32GT740 32" TV
GE 32GT740 32" TV Logo
62 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
