Question about Casio Exilim EX-Z750 Digital Camera
Focus I need to sharpen every photo using autofocus or manual focus. I have tried reset to default with same result.
  • 477 Answers
The problem lies in you lens. it is out of ajustment the focus motor and the zoom motor is out of sync. It needs to be reajusted or replaced. I repair these type of issues all the time and it is a common issue. hope this helps.
Posted on Apr 17, 2008
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Automatic mode is not working and the manual mode
The manual can be had from Nikon directly, here. The blurry results are probably due to an improper mode focus selection. Are you using a supported lens? A list of supported lenses is provided on pg. 157 of the manual, but this chart is easier to understand. Some lenses have an Auto / Manual focus selector switch. Some are shown as "A-M" or "A/M-M". Set an A-M switch to A or if A/M-M to A/M for Auto focus. Additionally, auto-focus is only supported on Nikon compatible lenses that bear the AF-S or the AF-I mark with built-in motors. If you've got a compatible lens attached, there may be a setting in the menu that is causing a problem. It will be far easier to simply reset the camera to factory default state than try to go through them all. See pages 119 & 124 for the Reset Shooting Options and Reset Setup Options procedure, and try shooting again.
Hopefully that will get you going.
Dec 15, 2010 | Nikon D3000 Digital Camera
I have a Nikon D40x digital camera. The problem began when the screen began showing some type of diagram over the picture I had just taken. The camera then started having difficulty with auto focus. ...
Seems possible that the servo control /main processor control is faulty and will need help from Nikon service , It will be better to get a evaluation for the fault and so we can have a consenses on the fault.
get estimate and decide.
Sep 28, 2010 | Nikon D40x Digital Camera
My gs500s colors are bright pink and i tried changing white balance and nothing works
Try going into "reset" master mode. otherwise you need to make sure your camera is shooting on the right setting for the light you are using. For example, when shooting in daylight with interior light setting (approx. 3200k) your photos will look off color and yellow or pink because sunlight is 5600k approx.,. . . contrary while shooting indoors with incandescant lighting if the camera is set for sunlight exposure (5600k) the picture will look blue. Make sure you read the manual on how to white balace, but first take the camera out of AutoExposure settings to do all the settings manually. Auto focus and auto exposure are for rookies and these types of errors will happen. Always try to do manual iris and manual focus for best results zoom in and get your focus on the subjects eyes then zoom out and frame up your shot.
Aug 03, 2009 | Panasonic PV-GS500 Camcorder
Macro Focusing Problem
try to master reset the camera...press menu...go to set up...highlight reset...go to yes then menu ok again....
Jan 06, 2008 | Samsung Digimax S500 Digital Camera
Built in Flash stutters...
This is the camera trying to give itself enough light to focus with.
As it uses contrast to focus with you will get problems in low light conditions. There's no way round this I'm afraid except to light the subject better. As it's a digital camera and you're not wasting film, try manual focus and see what results you get.
Nov 02, 2007 | Canon Rebel XT / EOS 350D Digital Camera
I tried to take a shot of the Vanderbilt baseball stadium, and it came out a little soft and out of focus. I was in Apperture priority at F8 to maximize the depth of field, exposure compensation -2/3EV,...
I've played around with the 'unsharp mask' filter in Photoshop CS, and I must tell you the results were amazing. I guess I should have mentioned that I'm very new to digital photography and I'm learning new things every day. I've had my FZ10 for 10 days now, and same goes for PS. By the way, do you know where could I find a good PS tutorial? The PS copy that I have came from my university's software licence department, with no manual. I know it is an amazing piece of software, and I want to learn.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Casio Exilim EX-Z750 Digital Camera Logo
130 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
