Question about Bose Acoustimass 15 System
Woofer not powering on
I am having problems with my woofer not powering on. I have taken it all apart and the fuse underneath the circuit board is good. I was wondering about the resistor. Could it be the resistor? What else can I try. All the sudden one day it will turn on out of nowhere. Every time I unplug the woofer or shut it off it will not power back on. Than out of nowhere in the next couple days it will power on.
Its your power
Posted on Jul 01, 2008
    Genius:
  • 1,067 Answers
Hows power strip your pluged into ? try differt outlets is it
srewed down tight to wood cabnit wires tight on speaker good grounded power how sthe wire going to it
Posted on Jan 07, 2008
Check the power unit inside woofer, it was cause for same problem in my creative surround.
Mar 30, 2008 | Bose Acoustimass 15 System
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
Feb 21, 2011 | Athena AS-P4000 Subwoofer
I need help on changing a fuse in PMP3000. The mixer went out on us one day, so I hooked it into an amp that we had. It works good as an unpowered mixer, but cannot get it to work as a powered mixer. I...
No, that is NOT what the problem is.
The fuse protects the power supply. The power amps have failed. The usual cause is an arc between layers of the multi-layer circuit board. The labor to repair the power amp module is extensive. I have repaired several.
You can find new amp modules and I would purchase a new one and drop into your unit. The amp module is an HCA2400.
There is probably $15 of parts blown in each side of the power amp and it takes about 6 hours to repair. One has to grind out the burned area (internal layers not necessarily visible on surface) and re-insulate and then install jumper wires to replace those taken out.
Each side of the amp will likely take out 3 switching MOSFET transistors and often a Zener diode. Sometimes a low resistance metering resistor will be fried with smoky residue underneath the board. When this happens two small surface mounted resistors will be blown open. Great care has to be taken when insulating the board damage and replacement of the blown circuit traces.
You can find HCA2400 power amp module replacements for about $175 online.
Use of the unit as an unpowered mixer is a bit dangerous as if arc re-establishes it can fry the power supply taking out two very expensive IGBT's and many other components. If the mixer still works, then your whole power supply is still OK.
Sep 09, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Peavey PR15-D Powered speakers, Power on but no sound.
Check for impedance ( resistance) in ohms on the speakers disconnected from the circuit using a volt/ohm meter. I think the woofers are 8 ohms and the tweeters are 8 ohms. Also check for bad solder joints where the jacks are soldered to the circuit boards.
May 31, 2009 | Peavey Pv 2600 Power Amplifier
Need to repair my HKTS 14 Harman Kardon Subwoofer
Since this is a power sub woofer, it may have an amplifier problem that would require professional service. Yoiu can start by checking the fuse. Make sure the sub woofer is not plugged into the wall when you check it. Some of these powered sub woofers have the fuse right on the panel where the cord goes into. It may have a round cap and you turn it and pull the fuse out. If the fuse is blackend or you can see that the filiment inside the fuse it broken, you can replace the fuse with the same rating of fuse. The rating is on the metal tab at one end of the fuse or may also be listed right next to the cap for the fuse holder. If the fuse is not accesable from the panel, you need to remove panel and look for it where the power cord comes into the panel. It will be right in line with the power cord. The panel for most sub woofers are normally held on by screws all the way around the panel. You should only need to take the outside screws (around the edge of panel) off of the panel. The inside screws hold on the circuit boards, connectorsm and transformer.
If you had given more information about the problem with your sub woofer I could have given you a better answer, but with the limited information given all I can suggest right now is to check the fuse. That is always a good starting point. If you give me more information I may be able to help you much more, I have repaired many powered sub woofers but not this model. Most are very similar and can be checked with minimal effort. You would need to have a multimeter to check almost everything else with the sub woofer. Let me know if you have a multimeter and are willing to check it further. Anything less than a "FixYa!" rating is really not a good rating, so please do not rate this solution until we have had a chance to communicate more about the problem. That way I will not be given a bad rating when I have not had a chance to actually help you yet since I can not tell you how to fix your problem without more information.
Dave
Oct 14, 2008 | Audio Players & Recorders
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Power Light off & speaker not working
I had the same problem. The screws around the perimeter of the back plate must be unscrewed and the plate must be pried off as it is glued to the box. When replacing my fuse, 2A 5x20 GMA, it blew the fuse again. Disconnecting the second circuit board prevented the next fuse from blowing, but now the question is what is wrong with the circuit board? I cannot see any damage or shorts.
Oct 10, 2007 | Kenwood SW-38HT Subwoofer
InFocus X1 power problem
something blew the fuse the first time. if it blew again, the issue remains. something may be arcing. check near the plug, or if there is anything bouncing around in there or a crossed wire.
Nov 26, 2006 | InFocus X1A Multimedia Projector
Bose Acoustimass 15 System Logo
363 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
