Question about Sony Ericsson W850i Cellular Phone
K850i the camera's lens cover doesn't open when I press button on. the screen is black and I can't take pictures. do you have idea what's wrong? tx
  • 1 more comment
  • MANIEKOK Jan 06, 2008
    IT'S K850i AND IN THIS PHONE LENS GOES AUTOMATICLY, SO I CAN DO IT!
  • Anonymous May 08, 2008
    same problem occur with my k850i, lens cover did not open, but i have solve it by tapping the top portion of the lens while turning the camera on, try it. ( bennyrm)
  • zoomzoom-nz Nov 17, 2008
    Same problem.
Turn it upside down, tap on plastic covering lens while pressing camera on.
Posted on Nov 17, 2008
So much thanks "guest" It works but can you explain me your comment of august 10 because I am confused a little bit becuase your first solution works. GOD BLESS YOU! :D
Posted on Oct 24, 2008
Im tapping like crazy and its not working lol
Posted on Aug 10, 2008
Got my solution with my k850i lens not open when swicth to camera function..... try tapping the upper portion of the lens while swithcing the camera function on...try it(bennyrm)
Posted on May 08, 2008
  • 3 Answers
The easiest way to take pics with the SE K810i, I just slide the lens cover and it auotmatically goes to camera mode
Posted on Jan 06, 2008
  • Emsy32
    Emsy32 Jan 06, 2008
    Apologies, I am talking aboout version, sorry
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Screen fluctuate/blinks when press left side keypad's buttons
u know ur phone emi number and send it 2 my sum1kewl_2009@yahoo.com
Apr 12, 2009 | Sony Ericsson K850i Mobile Phone
The cover lens of my k850i wont close
the camera trigger is damaged on the back of the main board needs to be replaced for software and hardware repairs contact kas at kas-anjum@hotmail.co.uk
Feb 17, 2009 | Sony Ericsson K850i Mobile Phone
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
K850i
just make sure your hands are not touching the side where the cam is... there is a sensor there that you might have been blocking while taking pics....
Dec 04, 2007 | Sony Ericsson W850i Cellular Phone
Black screen when I turn the camera on
You could be suffering from a frozen Iris. This is the part of the lens which varies the amount of light entering the camera. Or the lens cover may not be opening when you switch on. Have you tried pushing the middle button of the 3 which run vertically on the rear of the camera below the mode switch. I had one on my bench a few weeks back which had an intermittent black screen. It started of as black and when I stripped it, cleaned all contacts and put it back together it the flashed on and off. I then stripped it again and went over every cable associated with the lens, CCD and video board checking them for breaks and recleaning them and bingo, everything came good. I have another 72 at the moment with a similar problem, I fixed the same way but got left with lines running across the picture. P72's aren't the best cameras picture wise and are close to the most troublesome, at least around here. For any of the above faults I'd recommend a visit to your local tech. Good luck. BMW
Jun 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Ericsson W850i Cellular Phone Logo
290 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
