Question about Mitsubishi WS-55807 TV
Convergence issue on Mitsubishi
How much should it cost to repair a convergence issue with a MIT WS 65908? Also, once repaired, does it last or does the problem reoccur again?
    Genius:
  • 1,153 Answers
Check your error codes first and see what error it's given. If done right it would last. see ctechnicians.com for how to do error codes
Posted on Jan 06, 2008
How do I reset my Mitsubishi WS-65908
Model number here has 3 hidden menus--adjustment (keep out of that one) and convergence, and OPTION menu.
In the Option menu with the Mitsubishi remote you can do a hard reset of entire set--sets everything back to factory except convergence adjustments.
This requires the Mitsubishi remote and a 4 digit number code.
I am willing to give that but first would like to know WHY you wish to do that as it will not cure all problems like dead set, convergence etc.
Apr 16, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi HDTV 1080, model WS-55511. Color convergence is off but only on the outsides of the screen; in the center it is fine. Can this be fixed or do I need to replace the television?
Yes, it can be repaired, replace convergence out chips (two ICs) on main board.
If you are not comfortable with TV repair or have no experience, call local tech to fix it. Cost of repair would be $180 or so.
Nov 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My mitsubishi ws-55809 will not turn on
hi..
The problem is the Convergence circuit and the reason it does not power up is that one or two of the 5a pico fuses have opened when the Convergence IC failed. It is either going to be a pair of STK392-570's or a single IC STK393-110. That is as long as this set is a Mitsubishi made in the last 7 to 9 years.
I would estimate the cost to repair 280.00 plus service call fee if any, plus tax on parts.
Let the Tech check it out. If if it cost less than 400.00 to repair, it may well be worth taking the chance.
thank u
rate me
Jul 21, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Dec 05, 2008 | Mitsubishi WS-65908 TV
Mitsubishi
if the pic is concave you have a convergence circut problem, check the +/- 24 volts supply, if is down repair it and replace the stk's
Nov 08, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi prjection screen WS-65908
You have a convergence problem,all this sets show this problem sooner or later,you have 2 or 3 amps for the red,green blue colors and this amps go bad and need to be replaced then you have to do a convergence aligment from the service mode and not form the customer controls,a qualified tech should be able to correct the problem since is a common one.
Sep 09, 2008 | Mitsubishi WS-65908 TV
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55807 "Bow-Tie" Problem
If your not a tech, its highly advisable to not even open the set because of the high voltage and x-ray radiation issues. Now if your a technician ,you gonna need to get a service manual, Look up the convergence circuit, Find the two or three convergence driver ics, find the b+ feed resistors to those ic, and order the exact replacement parts. if you dont replace all at once, and with exact replacements, you will be in the same boat a few months down the road. This is not a repair a handi-person should consider doing as even if you get the ics replaced, your gonna need to do some minor or could be major convergence alighnment and your gonna need a cross hatch generator to do this. This repair should cost ya about 300 to 400 bucks? Sorry man Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
